  1. I'm running out of disk space and I need a storage solution. The problem is that I'm not finding great reviews for any of the single terabyte and up drives I'm running across.
    I also have a couple of external drives I would like to break open and stick the disk drives in a unified enclosure. Any suggestions on a reliable external SATA enclosure?
    Oct 2005
    666th portal
    the only TB drives i use are the samsung f3's. fast little buggers. my external drives just get stacked up like this.
  3. WD black edition
    $87.99 Free Shipping with Coupon Code: MADNESS15 (Exp 3/25 or 1500 uses)
    http://www.ewiz.com/detail.php?name=HD-W11FALS&c=CJ
    I bought the 750gb model with Thermaltake docking station when it was $22
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817153066
  4. As usual good advice on this forum. Do you have any issues with that style of external enclosure? Seems like it would definitely dissipate heat very well.
  5. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    Get a Samsung Spinpoint F3 1tb from Newegg, $89.99.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
