  1. I'm looking into getting a capture card for my Xbox 360. What are some good one's that are a reasonable price? I want to avoid hooking it up to the computer as much as possible, if it's possible. If not, I have a Compaq Presario PC. Will this work? I have a standard box TV, no HD or anything. Is there anyway to hook up the capture card straight from my Xbox to my TV? What equipment/items will I need for the complete setup?
    Mar 2010
    NJ
    Most people recommend the Dazzle for SD. All you need is the Dazzle (capture card) and 3 av splitters. You will need to hook it up to a computer as it needs to record to it, but you can still play the game on your TV.
    Search "Xbox 360 Dazzle" on youtube
  3. Thank you for your response. Would there be any other Capture Card's, resonable price obviously, in mind? I want to have a couple to research before I make my decision.
