I just encoded some test video to dvd with The Film Machine using HCenc, and Convertxtodvd with 2pass Lanczos filter.
What can I use to play these back side by side to compare?
Thanks.
edit: At exactly the same time. So no stupid answers, like "play the dvd in two separate instances with your video player". Or "Take screenshots".
I'd like to do this to not only compare quality, but sync and smoothness of video.
OK, so I can apparently use an AviSynth script in VirtualDub or MPC (HC)
But what file patch and code do I use for a DVD (VIDEO_TS) folder?Code:a=AVISource("pathtoclip1") b=AVISource("pathtoclip2") StackHorizontal(A,b)
Because the paths "C:\test1\VIDEO_TS" or "C:\test1\VIDEO_TS\VTS_01_1.vob" do not work.
I think an answers may be here:
http://nickyguides.digital-digest.com/synth-vdub.htm
but I don't have the time until tomorrow to check it out.
Surely there is a simpler way. I.e a tool that opens up 2 individual videos (DVDS)?
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 12:52 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 15:47 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 19:23 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 08:09 -
Merge 2 FLV video files side by side
By zsuppguy in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2010, 16:58
