    Nov 2002
    Italy
    Hi,
    I am using VirtualDub to mux avi + PCM files, since I am talking about 60 clips, I will be using the Job Control function.
    Is there a way to tell VD to delete the original source files (avi + PCM) to the recycle bin after every job control has ended?
    Thank you
    Alex
    AOPEN AX34, PIII 1.0 GHz, 1,5GB RAM, HD WD 120 GB, Pioneer DVR-116D, Plextor PX-716A, HIS Excalibur Radeon 9600, 256Mb, 2xMonitor Philips 109P20 Br Ethernet D-Link DE-828CT, Philips ToUCam Pro, WXP PRO SP3
    May 2001
    Unless VirtualDub has added a "shell" feature, I would say that the answer is "no".
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Nov 2002
    Italy
    Oops, that's a pity , alternatives to achieve the same result?
    Alex
    May 2001
    I can only think of DOS batch files as a possibility. You might want to check the docs on VD to see if it has any commandline options. Maybe you can import a Job Control file from the commandline. If so, you could write a batch file to do operations on a single video, then exit, then erase the files, then call VD with a different Job Control file, etc, etc.
    I don't know if this is possible, but if it is, this is how I would do it.
