Hi everybody ,
I tried to encode a .ts file ( from 1980 to 720 ) , those size is about 8,4 GB .
I made all required settings and it shows me 4,372,895 frames to be processed.
The time ??? Well , at least 34 hours..using RipBot 264
Is this situation a normal one ???
What should I do to accelerate the whole process of encoding ??
It sounds like transmission errors in the file. I would suggest running it through ProjectX in demux mode (only this mode repairs) and gets rid of junk. Then remux and then with the new mpeg file convert it to whatever you want.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If I wanna "repair" it , should I do any settings ?? Or just simply run it through tsmuxer ???
Baldrick
I've done like you told...nothing , no change
Any other suggestion ???
Does it help you technical details ??
Format : MPEG-TS
File size : 8.43 GiB
Duration : 52mn 32s
Overall bit rate : 23.0 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 52mn 31s
Bit rate : 21.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.338
Stream size : 7.70 GiB (91%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 52mn 32s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 3 channels
Channel positions : Front: L C R
Sampling rate : 44.1 KHz
Stream size : 144 MiB (2%)Last edited by Benjy; 24th Mar 2010 at 05:35.
ffmpegX taking LONG time
By macgurl in forum ffmpegX general discussionReplies: 1Last Post: 23rd Apr 2011, 00:50 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 09:39 -
Fast Computer Extremly long time Encoding
By doz in forum Video ConversionReplies: 5Last Post: 24th Apr 2008, 13:45 -
Media takes long time in intializing
By chankya in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Nov 2007, 23:10
using
