I have a LG DVD recorder RH1999H with a 250GB hard drive. A few years ago, the DVD writer broke, it was replaced but I lost all the movies on the HD.
The same thing is happening now- we can record to the hard drive, but cannot copy/write to a DVD.The recorder needs to be repaired, but I am worried that I might lose all the movies on the HD again.
Is there any way of saving/copy the movies on the HD?
Most likely it's standard procedure to re-image the hard disk when they repair it.
If you can personally talk to the people who do the repair, you might be able to stop them from doing that.
Otherwise you might take out the hard disk before you sent the machine in for repair, and replace it when you get it back with the new burner. But that might void your warranty. -
Thanks for your comments. Will phone them beforehand and see what I can do.
Just thought that there might be a way to download on an ext HD, but there is no USB connection in any case on that machine. -
If you know what you are doing you could open the recorder, remove the hard drive, and attach it to your PC and presumably copy the movies off it. But I've never heard of a DVD recorder that lets you copy stuff off the hard drive via some connection on the recorder itself like USB.
I used to have RH1777H (80GB). Within the first year of having it, the disc drive (i think they call it Loader) was already giving problems. The Tech Guy who helps usually just replaces the drive as it is the one with the problem. No installing of any software and everything in the HD is still there.
Not sure about saving/copy the shows though. It did tried once to detach it out from the set, plug in as a Secondary HD on a PC but it didn't detect as how you think it would. -
Here is a service manual:
http://www.jordansmanuals.com/Default.aspx?Brand=LG&Product=DVD-VCR&Model=RH1999H
FYI, I was able to hook up a standard PC DVD burner to an LG DVD recorder. The only potential hitch is that some interfaces use a narrow flex cable version of IDE rather than the 40-pin PC ribbon cable. In such cases you can use a small adapter PCB to convert the connector types. -
DVD Recorder not recognizing dvds
By JDiane in forum DVD & Blu-ray RecordersReplies: 29Last Post: 15th Apr 2019, 15:02 -
Copy DVDs on my DVD Recorder?
By manda13 in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2010, 10:46 -
Is it possible to finalize DVDs on another DVD recorder of the same brand?
By caleb89sw in forum DVD & Blu-ray RecordersReplies: 5Last Post: 10th Mar 2010, 22:22 -
write DVDs for Zone 1 & All Zones
By wasssu in forum Authoring (DVD)Replies: 4Last Post: 8th Jan 2009, 06:03 -
can write CDs okay but not DVDs
By johnsees in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 22:13
