I am looking at the Panasonic HDC-TM700K and it looks like what I need.
It takes video at 1920x1080 60P, it apparently does not have a 24P mode. Will this 60P burn to Blu ray alright and be able to be played in a Playstation 3?
Results 1 to 30 of 37
It looks like AVCHD DVD or BD is currently not compatible with 1080/60p. Full review for this new cam, HDC-TM700, is not available yet so we do not know what the user can do with the videos in terms of making high-def disc. See the discussion in the following forum:
http://www.camcorderinfo.com/content/Panasonic-2010-Flagship-Camcorders-HDC-HS700-HDC-...M700-37646.htm -
Have a look at the Canon T2I/550D. Same price ($100 less) , interchangeable lenses, short depth of field. Whatever camera you get, make sure you have an adequately fast computer to process AVCHD video.
Example of the built in microphone. Nice dog!
"Quality is cool, but don't forget... Content is King!" -
I tried a canon vixia hf S20 but it's 24p was really 60i so I sent it back
http://www.kiva.org/about -
None for consumer highly compressed AVCHD
I maintain most consumers would be best off with 1280x720p at 60 fps at 24 Mb/s since most won't use a tripod.
1920x1080p at 60 fps and 28Mb/s is way overcompressed.
Problem is consumers chase resolution where pros know bitrate and recompression loss rules the roost. At ~25Mb/s AVC you will get a better post edit picture from 1440x1080 source.
For lower compressed, higher bit rate pro models see
Sony XDCAM-EX
Panasonic AVC-IntraRecommends: Kiva.org - Loans that change lives.
Agree with all the above criticisms in theory - but "proper" manufacturers doing 1920x1080p60 at a half decent bitrate? WOW!
If the lens and sensor are up to it, and the H.264 compression doesn't wreck it, this could be wonderful.
Or it could herald a new era of specmanship / number-chasing where the actually picture quality takes a nosedive!
Cheers,
David. -
It is mainly an issue of h.264 hardware codec improvement to get 1080 60p down to 28Mb/s. It requires a huge jump in compression performance. This would be proprietary and outside the AVCHD spec. If this is just an extension of AVCHD, it there will be severe compression artifacts vs. 1080i 29.97 or 1080p 24
For pro performance, I'd rather see a model that captures directly to a digitial intermendiate format on hard disk with higher compressed flash RAM as an option.Recommends: Kiva.org - Loans that change lives.
Following is a link to Panasonic web site, showing play back options for the HDC-TM700:
http://www.panasonic.net/avc/camcorder/hd/hs700_tm700_sd700/feature3.html
It looks like there is an option to save 1080/60p video data to the PC. To play back, one has to either: (1) play the video directly from the cam to a TV, or (2) make an AVCHD DVD to to played on a BD player. Both of these playing options are with 1080/60i. I am not sure why we want 1080/60p video in the first place (?). Perhaps, there will be a modified AVCHD version to allow playing 1080/60p in the future. -
My old camera does 1920x1080 @17Mbps and it looks great outdoors. It dose not look so great indoors.
Blu-Ray and ATSC don't support 1080p at above 24fps. But quality 1080 60p is very useful for post production. You can edit and process progressive then convert to 1080i/29.97 or 1280x720p/59.94 at export. But garbage in garbage out. Over-compressed h.264 would qualify as garbage.
It may be possible to capture 1080 60p HDMI live directly to a BlackMagic Decklink or AJA Kona/Xena to a hard drive thus avoiding AVCHD encoding. We shall see. The Intensity pro only does 1080i.Last edited by edDV; 27th Mar 2010 at 15:11.
I would prefer to stick with the 24P but do need a new camera that does better in low light conditions,a higher bitrate would be nice also
24p has disadvantages vs. 1080i and 60p and some advantages.
I maintain 1280x720p at 50/60 fps would be the better format for most consumers.
See this thread.
https://forum.videohelp.com/threads/294510-List-of-really-true-native-24P-1920x1080-AVC...corders/page2?Recommends: Kiva.org - Loans that change lives.
Most of my video capturing has been with a Canon 7D at a mix of 1080p and 720p resolutions and frame rates and generally I find myself agreeing with edDV. As much as it pains me to give up resolution, 720p at 60fps is smooth, and it's also incredibly easy to edit....
Hi,
I will appreciate your choice really its a great Panasonic Videokamera HDC-TM 700 EG-K it has good functionality that we want in our camcorder -
I want 1920x1080 @24P because it can go to blu ray without any conversion
Also that is what my old camera shoots and it is beautiful except in artificial light -
You should buy Sony HDR-CX550!
Raw files
http://www.videoaktiv.de/Table/Testvideos/
also http://www.youtube.com/watch?v=TnfOGqmoQ-I
and http://www.youtube.com/watch?v=JM-Q0LK-674&feature=related -
deinterlacing messes up the sharpness
I want a cam that can do 24p without any BS motion is jut fine with my old cam @24p it is the lighting that is the issue with itLast edited by Onceler2; 13th Apr 2010 at 09:45.
BS motion? If there is little motion you can get away with 12 fps.
Motion and the way it is handled is the point. Most people want a camcorder that can be hand held.
As for low light, it comes down to the size of the sensor and the diameter of the lens. In other words, a more massive camcorder. The sensor and lens are the major cost components of a camcorder so that means a more massive and expensive camcorder. The DSLR form factor optimizes for large sensors and large lenses, but is very difficult to hold steady for motion recording. The placement of the LCD monitor forces arms into an unstable position increasing camera shake motion. A tripod is a must. Broadcast style camcorders are optimized for stable, on shoulder shooting.Last edited by edDV; 13th Apr 2010 at 11:53.
for low light conditions there is no better camcorder than sony hdr-cx550v at the moment. Deinterlacing does not messes the sharpening! You just need more advanced deinterlacing filter. I would start with yadif then you could check Yadifmod+edi
If you like long processing times and problems go for it, or else stick with an SDVD capable cam. Unless you are really knowledgeable and have the best equipment-software, you will be in trouble fast. Look into Canon cams for the above capability and wait for this technology to develop.
You're suggesting people shoot SD in the developed world in 2010?!
Mad.
HDV is no problem to edit at all. Even on a fairly old PC. Sony Vegas HD runs fine on my 2.8GHz P4 (over 5 years old!).
AVCHD can still be a challenge on older machines, unless you use an intermediate codec. So use one, or pick HDV instead.
Don't shoot SD in 2010! Not unless you only want SD right now, and will bin your footage within months.
HD is essential for any longevity. Essential for now for most people.
IMO! YMMV!!!
Cheers,
David. -
Agreed...I saw a little used HDV cam for $150
No excuses left not to be shooting in full HD
I've been editing HDV for 3.5 years now and simply forget it's HDLast edited by zoobie; 16th Apr 2010 at 02:06.
Thinking of buying a Apple Imac to transfer old videos
By Happyfeet2 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2011, 04:25 -
Buying Camcorder
By Nanflexal in forum DVD & Blu-ray RecordersReplies: 9Last Post: 25th Jul 2009, 16:14 -
Aussies thinking of buying computer gear online, CAUTION.
By blinky88 in forum ComputerReplies: 1Last Post: 29th May 2009, 04:03 -
Thinking about buying a PSP
By Bamahusker in forum DVD RippingReplies: 7Last Post: 14th Jan 2008, 23:15 -
Thinking of buying my first Mac soonish
By Nilfennasion in forum MacReplies: 11Last Post: 31st Jul 2007, 10:15
