I have a video in this format. It cannot be played on PS3. I tried to convert it using handbreak, AutoGK and Divx but it does not load. I don't know what else to use
Film.mpg
Video: MPEG4 Video (H264) 1280x720 23.98fps [Video]
Audio: Dolby AC3 48000Hz 4ch [Audio]
Code:General ID : 1 Complete name : C:\Users\Users\Desktop\Films (2007).mpg Format : MPEG-TS File size : 1.53 GiB Duration : 1h 2mn Overall bit rate : 3 501 Kbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Duration : 1h 2mn Bit rate : 2 618 Kbps Nominal bit rate : 2 680 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.118 Stream size : 1.15 GiB (75%) Writing library : x264 core 58 r798M 17e5dac Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=2 / deadzone=6,6 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=2680 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.7:15. Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 2mn Bit rate mode : Constant Bit rate : 640 Kbps Channel(s) : 4 channels Channel positions : Front: L C R, Surround: C Sampling rate : 48.0 KHz Stream size : 287 MiB (18%)
How to convert any video to MP4 iPod, iPhone, PS3, XboX360 using free tools
By Baldrick in forum User guidesReplies: 74Last Post: 6th Apr 2014, 23:03 -
MP4 with 2.0 audio: the only HD format compatible with BOTH ps3/xbox360?
By Randm in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 13:09 -
on/off subtitles for both PS3 & XBOX360?
By Randm in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 04:11 -
Large MKV (h264) File to PS3 MP4 without re-encoding
By icue in forum MacReplies: 0Last Post: 29th Sep 2008, 18:14 -
mkv to h264 xbox360?
By Ducco in forum Video ConversionReplies: 0Last Post: 14th Jun 2007, 18:57
