Removed.
stand alone for your TV? or your PC?
for TV check the WD TV Live HD
http://www.amazon.com/Western-Digital-Network-ready-Player-WDBAAN0000NBK-NESN/dp/B002K...9354067&sr=8-1
ASUS O!Play
http://www.amazon.com/ASUS-Play-Media-Player-Black/dp/B002MCZJ3C/ref=sr_1_8?ie=UTF8&s=...9354237&sr=1-8
brite-View BV-5005 HD CinemaTube multimedia player with Torrent client
http://www.amazon.com/exec/obidos/tg/detail/-/B002CNOYRS/ref=ord_cart_shr?_encoding=UT...X0DER&v=glance -
I recommend the WD TV devices if having a very small form factor and being able to play from USB (there is NO internal storage of any kind and no disc drive unless you attach one via USB) is important to you. However, they aren't necessarily the best at DVD playback. I don't use mine (the older WD TV HD unit, not the WD TV Live HD) for DVD playback at all. I did a little testing and it seemed to me that these just went to the main movie on the DVD and I wasn't able to make it go to the menu. DVD playback devices are much inferior for MKV and Divx playback though, so it's really hard to have a "one device for everything" solution. I use the WD TV for Divx/MKV/etc. playback and a DVD or BluRay player for DVD playback and it works great for me.
My caution against using DVD players for this purpose also applies to BluRay players. Don't come back bitching here if you buy it and you find that some of your MKVs won't play. DVD and BluRay players always have limitations in the firmware about what they will play for things like Divx and MKV.
Suggest decent, cheap DVD player for divx/xvid/mkv
By Batchman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th Mar 2012, 17:33 -
Dvd, Divx,Xvid,Mkv,Blu-ray... player
By jarko in forum DVD & Blu-ray PlayersReplies: 5Last Post: 7th Jun 2010, 12:16 -
Hardware needed to convert MKV to AVI and dvd etc quicker?
By spunge85 in forum Video ConversionReplies: 1Last Post: 16th Jan 2010, 07:40 -
Any reason why most dvd player only support xvid, divx and not rmvb and mkv
By c1steady in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2009, 20:14 -
Many questions on MKV to AVI for DivX player
By MasterRoshi in forum Newbie / General discussionsReplies: 5Last Post: 21st Jan 2008, 12:42
