WhenI load this cue sheet and burn the bin using CDRWin I keep getting an audio cd but, there are no accesible files when I open it. The CD shaws that there is 500 megs on it but, I can't seem to find anything at all. Could it be the que sheet???
FILE "BHD2.BIN" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 00 00:11:21
INDEX 01 00:13:21
Thanks in advance to anyone that can assist me.
what version of CDRwin? and have you tried burning that one in Nero ( FILE--BURN IMAGE---LOAD UP CUE SHEET, BURN ), you got a mixed mode bin there with 2 audio and one data track, or the 2 audio are fake tracks. you can view the contents of the bin in cdmage as it will view and extract the tracks.
You didn't use a crack on CDRWin did you?
http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
Regards.Michael Tam
w: Morsels of Evidence -
I use Blindwrite Suite 1.2.3, it works all the time for me with cue/bin file VCD's & SVCD's.
Sorry guys. I am a dipshit. I forgot to turn the auto insert notification off and turn on sync data transfer on my burner. Thanks for you advise.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
