With my motherboard I'm only able to use the CPU fan connection and one case fan connection.
I want to use maybe one or two more fans but I'm not sure what the cable is called that allows you to run a fan straight from the power supply. If someone could let me know what to look for or maybe provide a link to one on Newegg or another site would be great
Thanks for any help.
Results 1 to 10 of 10
What? An internal Y power connector, or a 3 or 4 pin connector? I have an Antec 3 speed LED TRICOOL 80mm case fan it lets me choose the power source it has a 3 pin connector & 4 pin adapter with pass-through.
I would like to be able to use fans I already have via peripheral connector.
I see that some fans let you choose which way to hook it up, mobo or PS, but would like to use the ones I already have.
Would the Y connector drain power from any of the fans?? -
So you are looking for something like a splitter for the case fan connector?
The Y power connector would just transfer power from the power supply via the board in the fans as was needed.
get a multi fan power port.
http://www.petrastechshop.com/sumufanpopo.html
I use those when the mobo only has 2 fan headers...i prefer using that instead of the molex power.
What is this device? (rf in-out with power supply?)
By cynikalhedonist in forum Capturing and VCRReplies: 11Last Post: 23rd Mar 2011, 12:11 -
Power supply numbers
By kenmo in forum ComputerReplies: 11Last Post: 14th Jan 2011, 10:18 -
Bad Power Supply
By AuroEdge in forum ComputerReplies: 4Last Post: 14th Jan 2010, 00:41 -
Power Supply Question
By jjis in forum ComputerReplies: 10Last Post: 6th Nov 2009, 08:35 -
Power supply problem?
By Ai Haibara in forum ComputerReplies: 17Last Post: 22nd Oct 2008, 13:54
very cheap.
