See above:
http://www.webxpace.com/software/freeware.shtml#WvPlayer
Tiny program. Very simple. But very charming. :P
WV PLAYER
Play all your Multimedia files... can play any multimedia files, from
sound to movies, WAV, MIDI, MPG, AVI, MP3, ... in fact anything you
want, provided you have all the necessary filters and codecs available
in your computer.
This uesed to be named WavPlayer, so it really is the same program and
not a diferent one. But the name was a little misleading, as it didn't
stop at wav files only. It was called WavPlayer, just because it started
it's life as a simple WAV player...
Then, it naturally evolved to a full multimedia player.
Can play videos zoomed and full screen, show frame rate and play in
slow motion (not all, just some..), save AVI individual frames as JPG
to disk, etc...
Also has a special 'kiosk mode' that shows the interface centered in
the middle of the screen, with no caption and a few menus disabled,
for a few special uses.
Works with multiple soundcards for playing WAV files, if you are
lucky to have more than one (soundcard) installed - or want to send
different 'voice' commands to different sound interfaces. This works
even from the command line.
Has a full 'play list' to were you may add any files you want, and
let it play all unatended, amoung a few other goodies.
Can also work only from the command line, using a string like:
"{path_to_program}\wv_player.exe" /n{path_to_file}\sound.wav"
to play only the files and auto exit.
To make it clearer, here is a command line example:
* you have player (wv_player.exe) in folder C:\Programs\utils
* you have a file to play (sound.wav) in folder C:\win\sounds\
so, command line, with above example, should go like this:
"C:\Programs\utils\wv_player.exe C:\win\sounds\sound.wav"
And if you want to repeat the playing, there is an extra option;
so if you want the sound to play twice:
"C:\Programs\utils\wv_player.exe /n:2 C:\win\sounds\sound.wav"
And if you want to play (wav file) it on a different soundcard - lucky you
there is another option; so to play it twice on your second card:
"C:\Programs\utils\wv_player.exe /n:2 /c:1 C:\win\sounds\sound.wav"
The /n: switch is the number of times the command line will repeat
playback, and must be right after the program's name, before the
filenames to play. Note: to stop the playback in command line mode,
just use the combination Ctrl+Break keys.
The /c: switch is the soundcard's number you want to play on.
Just note that 1st soundcard is numbered 'zero' (0). second is
numbered 'one' (1), etc... Note: multi-soundcards only work for WAV
files
Ah, and don't forget that command lines that have spaces in it are
required by Windows itself to be between "". So, an example with spaces
in the path name could be like this:
"C:\Documents and Settings\wv_player.exe" "C:\Documents and Settings\wav\Missing.wav"
(note that both parts of the command line are between "" as both have
spaces in it...
Install / Uninstall
Never liked programs that install files all over the hard disk;
To install this program, you only have to copy the files to a
suitable directory, and then run it from there.
To uninstall, you only have to delete the directory you created and
the files within, and... that's all !
Contact me
If you wish to sponsor development of other handy utilities,
or you enjoy using this viewer so much that you can't resist...
Please find the time to mail me regarding problems, enhancements or
donations. Enhancements that I consider to be worth while,
I will add and both mail the enhanced version to the specific person
and also re-post it to any server site which has agreed to house it.
You can e-mail me at jmfalcao@webxpace.com
Free Downloads
And, of course, you can always download the latest versions of
the software from my web page, at
http://www.webxpace.net/software/software.html
Disclaimer
Anybody may use or copy this program free of charge.
However if anyone wishes to make any volume distributions, CD's
and the like I would very much like to be asked first.
I must stress that they do so at their own risk. I can't be held
responsible for this program or any other programs malfunction.
As this is freeware, it can be used freely in any FREE use...
If you are using it on any commercial application, you need to
ask first.
Thank you
A big Thank You to all the people that cared to donate a few $$$
to help keep the development of this freeware alive. Those are
truly the ones that believe those utilities are worth something
and keep me motivated creating and improving freeware!
And also for the help and trouble of writing back with feedback
and suggestions, to :
Keith Tonge
Kurt San
Greg Ackerson
Dale Hawthorn
Milton Xavier
B. james
Ken Garris (multi soundcards)
Denys Jones
Liv De Lange
Michael Marquart
Henry Schwartzman
Carl Sawyer
© 1998-2009 J.Falcao
Thanks.
Results 1 to 1 of 1
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Player nightmare! (BS Player and Media PLayer Classic)
By 2710 in forum Software PlayingReplies: 1Last Post: 9th Jul 2010, 07:28 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
