Results 1 to 12 of 12
  1. Hey guys, Im just wondering how you can tell when/if a dvd burner is bad. I Currently use an LG GH22LP20 burner and as of last night it will not burn faster then 1.6x anymore. Nothing unusual happened, I do think ive burned well over 2k discs on it. Any advice/suggestions? Thanks
    BTW I use the latest version of IMGBurn.
  2. I am not surprised. I have a LG DVD player died after 6 months.
  3. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    It's probably not bad, just running in PIO mode. Delete your primary or secondary IDE controller (whichever the drive is on) or both of them (to be sure) from your device tree and reboot.
  4. @GKar- Thanks a lot bro it worked. I removed the drive and updated to latest firmware and everything is running smooth as silk. I have to be honest with you, this is one of the better drives I've ever owned. Cheers!
  5. Member GKar's Avatar
    Jul 2003
    I have two of them myself. If you want to get a little more out of them on the ripping side you can try Mediacodespeededit to patch it and get up to 16x read speed out of it, worked for me (depending on the media of course).
  6. Thanks mate, it does work. Cheers!
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I'd bet you are pretty damn surprised now though huh? Well maybe not. You've been getting "smacked around"
    and proven dead wrong for quite a while about your alleged bad experience with an LG player.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Even easier, the latest ImgBurn has a function to do that: Tools/Reset DMA.
  9. Member GKar's Avatar
    Jul 2003
    Yeah, forgot about that. I'm still using the ancient but venerable Nero 6 Ultra.
  10. Video Restorer lordsmurf's Avatar
    LG isn't a very good brand/manufacture of burner, no.
  11. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I didn't care for the older LG models but I do have a H62L drive which is still working well....in fact it can read some discs that are scratched which my other drives can't....must be cause the read speed is locked...newer models are ok IMHO...I did buy a LG Bluray rom...works fine for me.
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    My 3 old LGs are still going strong. My newest is the H58N, next oldest is a 4167B, and the oldest is a 4040B. All still work perfectly. My uncle who owned a car dealership always said "The only thing wrong with that car is that loose nut behind the wheel"....
