    Sep 2008
    Bulgaria
    Hello all,
    Recently I have this strange problem with WinAVI Video Converter 9.0 everytime when I try to convert a mp4 file that's 25fps to avi I get like 28.148fps (in the AVI Encoder.ini file the fps is set to 25). Does someone knows what the problem might be?
    What says that the avi is 28.148fps? Does it not play ok?
    I would just try convert with something else like the simple winff or if you want more settings use xmedia recode.
    Sep 2008
    Bulgaria
    Thanks for the suggestions I'll try them both.
    Sep 2008
    Bulgaria
    I tried them but I liked more winavi video converter how it works. I fixed my problem but now I have another one. In the Avi Encoder.ini file the VideoFrame is set to 23.976 (VideoFrame=23.976) and when the converting process finishes the output video file is with 23fps can someone tell me what's wrong with it? I tried with 23.976 and 23,976 it doesen't work... I'll appreciate any solutions for this problem.
