Why does AVSTODVD want to resize my video? Also why is SSRC failing?
Error is: "ERROR, SSRC: could not resample between two sample rates."
Code:<3/22/2010 12:18:50 PM> START PROCESS <> <3/22/2010 12:18:50 PM> PROJECT SETTINGS DVD Video Standard: NTSC DVD Titles number: 1 DVD Size: 42/4450 MB (1%) DVD Output Setup: MPEG2 File DVD Label: DVD DVD Menu: No Menu Output Folder: C:\video\out Delete Temp Process Files: Yes Delete Working Files: Yes Edit Command Parameters: No Post Process Task: Show Progress Status window PREFERENCES AVS Source Filter: DirectShowSource AVS Resize Filter: Spline64Resize Video Resolution: 1 Video BitRate Min: 4500 Video BitRate Level 1: 8000 Video Profile Level 2: 4500 Video BitRate Max: 9000 Keep DVD Compliant Video: 0 AC3 Audio Encoder: 0 DVD Audio Format: 0 DVD Audio BitRate: 192 Keep DVD Compliat Audio: 0 Normalize Audio: 0 DVD Audio Language: EN - English DVD Subs Language: EN - English Chapthers Interval: 5 Use Source Chapters: 1 DVD Burning Drive: M: ATAPI DVD A DH16A1L KH39 DVD Burning Speed: 4x Auto Erase DVD RW: 1 Save Log file: 1 Unload ActiveMovie library: 0 Adjust ffdshow mixer: 1 <> <3/22/2010 12:18:50 PM> TITLE 1 SOURCE FILES Video: C:\video\out\2005-01-09 181343.avi Info: Huffman - 48231 kbps - 720x480 - DAR 1.5 - 29.97 fps (CFR) - - 38 seconds - 1150 frames Audio: C:\video\out\2005-01-09 181343.avi Info: PCM - 242 kbps - CBR - 7575Hz - 2ch - 38 seconds Subs: [MediaInfoLib - v0.7.26] <> <3/22/2010 12:18:50 PM> AVISYNTH SCRIPT Video = DirectShowSource("C:\video\out\2005-01-09 181343.avi", fps=29.97, convertfps=true, audio=false) Audio = DirectShowSource("C:\video\out\2005-01-09 181343.avi", video=false) Video = Video.ConvertToYV12 Video = Video.AddBorders(0,30,0,30) Video = Video.Spline64Resize(720,480) Audio = Audio.SSRC(48000) AudioDub(Video, Audio) <> <3/22/2010 12:18:50 PM> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 40.8 MB HCenc Parameters: -ini "C:\Users\p14000\AppData\Local\Temp\DVD_1_2005-01-09 181343.HCenc.ini" HCenc ini file: *INFILE C:\Users\p14000\AppData\Local\Temp\DVD_1_2005-01-09 181343.avs *AVSRELOAD *OUTFILE C:\video\out\DVD_1_2005-01-09 181343.m2v *LOGFILE C:\Users\p14000\AppData\Local\Temp\DVD_1_2005-01-09 181343.HCenc.log *MAXBITRATE 9000 *BITRATE 9000 *PROFILE BEST *ASPECT 4:3 *PROGRESSIVE *BIAS 90 *DC_PREC 10 *MATRIX MPEG *AQ 1 *LUMGAIN 0 *SMP *PRIORITY IDLE *WAIT 2 <> <3/22/2010 12:19:17 PM> PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS. CHECK LOG FILE <C:\VIDEO\OUT\DVD_1.LOG> FOR MORE INFO. <> <3/22/2010 12:19:17 PM> Log file created by AVStoDVD Release 2.2.6 <>Code:General Complete name : c:\video\out\2005-01-09 181343.avi Format : AVI Format/Info : Audio Video Interleave File size : 222 MiB Duration : 38s 372ms Overall bit rate : 48.5 Mbps Writing library : VirtualDub build 32706/release Video Format : Huffman Codec ID : HFYU Codec ID/Info : Huffman Lossless YUV and RGB formats (with Alpha-channel) Duration : 38s 371ms Bit rate : 48.2 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 1.500 Frame rate : 29.970 fps Standard : NTSC Bits/(Pixel*Frame) : 4.657 Stream size : 221 MiB (99%) Audio Format : PCM Format settings, Endianness : Little Format settings, Sign : Unsigned Codec ID : 1 Codec ID/Hint : Microsoft Duration : 38s 372ms Bit rate mode : Constant Bit rate : 242 Kbps Channel(s) : 2 channels Sampling rate : 7 575 Hz Resolution : 16 bits Stream size : 1.11 MiB (0%) Interleave, duration : 34 ms (1.01 video frame) Interleave, preload duration : 500 ms
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 21:37 -
AVStoDVD Crashes
By Bonie81 in forum Newbie / General discussionsReplies: 3Last Post: 12th Oct 2010, 08:53 -
New AVStoDVD user got some questions this software
By rock_king_my in forum Authoring (DVD)Replies: 8Last Post: 16th Sep 2010, 19:05 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 08:29 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 06:01
