Results 1 to 10 of 10
  1. Member vegasarian's Avatar
    Apr 2006
    I have a cheap computer mic (Creative) which I use for Skype and it works fine but I would like to be able to use my ECM-77 Lapel mic or Senny 416 to record V/Os. Neither of these two mics are being picked up by the computer. Everything in audio settings is maxed out, Mic boost is on but still nothing. Is there extra hardware I need to add in order to use these "pro" mics on the comp?
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    What type of sound card do you have? If it is onboard, many of the motherboard sound chips do not work very well (or at all) with the higher grade mics.
  3. Member vegasarian's Avatar
    Apr 2006
    Ah! that could be it then. Its on an Intel Core 2 Duo - MSI MS-7246 motherboard. Any recommendations as to a minimum priced sound card thats going to satisfy my mics? Or am I looking at big bucks to get them working?
  4. Greetings Supreme2k's Avatar
    Feb 2003
    A cheap Soundblaster Audigy or x-fi will do, for about $30 or so. You can probably get a pci-e card for that price if you shop around.
  5. Member vegasarian's Avatar
    Apr 2006
    Many thanks for your help Supr.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Pro mics need a 600 ohm XLR type connection for best performance. The Sennheizer needs "Phantom" 48vdc power.
    A cheap solution for voice over (ECM-77) is the Behringer 502 mixer that will raise Mic to line level and allow mixing other sources. It doesn't suport 48v Phantom power.
    http://www.amazon.com/Behringer-502-5-Input-Mixer/dp/B000J5UEGQ
    Other solutions in this article
    http://www.musiconmypc.co.uk/art_connect_microphone_to_pc.php
    http://www.kiva.org/about
  7. Member vegasarian's Avatar
    Apr 2006
    Interesting links edDV.
    I think you just solved my problem. I already have an SQN-4s Audio Mixer -
    http://www.sqn.co.uk/old/n4s/SQN4S.html
    which are quite common with news crews here in the UK.
    Being a cameraman and not a sound engineer it didn't occur to me to put the mic through the mixer before PC. (It also supplies 48v phantom power to the 416). Will give it a go tmrrw.
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you have a beachtek or similar pro mic to cam unit, you could probably use that.
  9. Greetings Supreme2k's Avatar
    Feb 2003
    I actually should have suggested the Griffin iMic, which I have. I got one on eBay for about $12 total. Here's an example of one, with the XLR cable
  10. Member vegasarian's Avatar
    Apr 2006
    Thanks for all the help. Both mics work fine when put through the audio mixer.
    You guys in the States get real bargains.That mic on ebay in the UK is around 45 dollars!
    http://www.google.co.uk/products?hl=en&source=hp&q=buy+imic+ebay&gs_rfai=&um=1&ie=UTF-...ed=0CBkQrQQwAA
