Hi just wandering is there any way to stream my PC audio to my TV via my HDMI cable that I'm using for only video at the moment.
Cheers,
shorto
The GPU has a sound device on the card itself if I can remember right. You may have to disable your onboard sound such as your Realtek or whatever you have and then see if Windows detects any audio device.
Be sure that your all up to date with your bios version and GPU drivers. -
You can also search through these common questions from the ati website.
http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.4.1&product=2.4.1.3.36.3.2...audio&items=20
It may depend on your OS and something to do with the Catalyst Control Center. It may need to be updated or I think it may read the default connections as DVI if your using XP so you would have to change it to HDMI -
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
I'm a little confused.. Which card is being used here??
Look at these 4870 cards on Newegg, they have HDMI connections
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201305520549%20...on%20HD%204870
Go to the link I provided earlier and they talk all about the problems with the audio streaming through the HDMI for THIS card. Click the right question in the link and you'll get your exact problem.. one that I think you may have anyways shorto -
I was looking at a picture on the AMD site. Looking at the products at Newegg, my favorite spot too, show different manufacturers with different connections. Some dual DVI with included HDMI adapters, some with one each of DVI and HDMI and some with dual HDMI.
However, the ATI version does seem to have dual DVI:
http://www.firingsquad.com/media/article_image.asp/2372/06Have a good one,
neomaine
Ok, so I guess we need some more info from you shorto. It does say ATI Radeon 4870 in the thread header but a lot of people list their card like that even though they have a XFX or whatnot.
I figured you had the HDMI output since you said "via HDMI cable" not stating that your using an adapter sooo... which do you have??
Either way your question should be answered. Good luck
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 16:33 -
WTB: Epson Perfection 4870 PHOT
By LSchafroth in forum Off topicReplies: 7Last Post: 16th Dec 2009, 22:34 -
no sound with radeon 5770 over hdmi
By lordhutt in forum ComputerReplies: 0Last Post: 20th Nov 2009, 15:14 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
