I am setting up HTPC with Hauppauge HD PVR and I have a ton of questions.
1) It appears that both the TS and M2TS files saved by the PVR are interlaced according to what I am seeing during playback and also reported by Mediainfo. Is there any way to capture deinterlaced or does that have to be done after capture? If after capture what application would be best to do that.
2) The only mpeg editor I've found so far to edit TS directly is TMPEG DVD Authoring Works 4. It appears that TPMEG DVD Authoring Works re-encodes after trimming; is there a way around this? Are there other applications that are better suited for trimming out commercials and also provide deinterlaced output. I tried Moyea Converter but did not care for the imprecise frame editing.
3) For archiving on hard drive is there a single file format that is better than others for both captured video and ripped DVD/BD. I have been saving as ISO but not sure that makes sense.
4) If anyone is aware of a good guide that will help me with these and many other questions related to PVR capture I would really appreciate posting that link.
If you capture 1080i it captures Interlaced, If you capture 720p or 480p it isn't interlaced.
It captures whatever you feed it.If I'd known I was going to live this long, I'd have taken better care of myself.
New User Registration
By ttyke32 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Aug 2011, 10:44 -
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 09:26 -
New user
By Ppeter in forum ffmpegX general discussionReplies: 11Last Post: 21st Mar 2009, 07:16 -
User Right
By Johnnylee_hang in forum ComputerReplies: 2Last Post: 12th Jun 2008, 04:11 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
