I used to capture video from a DV camera, successfully, via firewire with a normal modular PC and a fast Hard disc. Now I would to do the same task with a laptop and then I would like to know wich laptop I could buy.
Have a good day
Results 1 to 9 of 9
Buy the laptop only with 1394 input ( the firewire card already factory pre-installed )
If you already have a laptop without 1394 interface, buy a FireWire adaptor on PCMCIA slot or ExpressCard slot.
Hard drive performance has increased to the point where almost any new drive is going to keep up with most routine video capture duties. There are some excellent 500GB laptop drives on the market that are fast (faster than desktop drives of just a couple of years ago), cool-running and relatively inexpensive. Match this with virtually any dual-or-multicore processor and stay away from the bloatware, and you'll be just fine.
Just a last question:
Is it sufficient a 5400 rpm or I need a 7200 rpm hard disc?
have a good day -
For DV capture is 5400rpm will be fine, 13gb/hour or 3,6 Mb/s. Today 2.5 inch drive can handle minimum 25 Mb/s.
Thank you danno78 for your answer. I will save a lot of money buying a laptop with 5400 rpm HD instead 7200 rpm
Have a good day
Capture video to anything besides a PC or laptop?
By gamermom in forum Capturing and VCRReplies: 1Last Post: 11th Dec 2010, 09:22 -
Video Capture Advice
By Windu in forum Capturing and VCRReplies: 6Last Post: 15th May 2009, 12:30 -
Capture video signal from a camera to a laptop
By Cazz in forum Capturing and VCRReplies: 4Last Post: 15th Feb 2009, 16:17 -
Need specific advice on MacBook-based video editing before buying a laptop!
By psychotronicfilms in forum MacReplies: 12Last Post: 28th Feb 2008, 17:47 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18
