  1. on my Panasonic BD80
    used the option "force black fill for non-compliant" and the Panasonic output, of course
    tried with a compliant file and it worked great
    here is the mediainfo of the file with the problem:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 855 MiB
    Duration : 1h 57mn
    Overall bit rate : 1 017 Kbps
    Encoded date : UTC 2009-11-08 18:22:52
    Tagged date : UTC 2009-11-08 18:22:52
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 1h 57mn
    Bit rate mode : Variable
    Bit rate : 900 Kbps
    Maximum bit rate : 16.5 Mbps
    Width : 1 280 pixels
    Height : 528 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.056
    Stream size : 757 MiB (89%)
    Tagged date : UTC 2009-11-08 18:23:47
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : Yes
    Format settings, PS : No
    Codec ID : 40
    Duration : 1h 57mn
    Bit rate : 114 Kbps
    Maximum bit rate : 150 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 32.0 KHz
    Stream size : 95.9 MiB (11%)
    Language : English
    Encoded date : UTC 2009-11-08 18:23:46
    any ideas that dont involve hours of reencoding just to add some black bars?
  2. No, there is no other way. You need to transcode the file - multiAVCHD can do it for you.
    Btw, what version of multiAVCHD did you use that works in your player? 3.0 or 4.0?
    Laugh and the world will laugh with you. Cry and you will be alone
  3. guess I'll try the transcoding option then, and see how it goes
    oh, and I'm using version 4
