My problem stems from my ffdshow settings... (I use CCCP)... whenever I select lets say 3/2/1 6 ch, I can encode my m2ts' beautifully with avs2dvd. Whenever I go to check the settings afterwards it has been reverted to 2/0 stereo. I guess my real question is this... I have realtek hd audio console from Gigabyte, the audio settings in control panel, and CCCP... is there a way to set it up so I don't have to change things in CCCP before encoding? I don't understand why it keeps reverting other than one or more settings is conflicting with another... I'm totally newb please help! I use avs2dvd and CCCP codec pack.. other than that I have run insurgent and CCCP is all I have...pretty simple system but I can't figure any process of elimination that works.
Results 1 to 14 of 14
better yet... the question is this... what is reverting my settings back?.. everything will stay as planned with my control panel audio settings, my motherboard (realtek hd) settings, and my CCCP settings can all be put to 6 ch... NO PROB! All programs continue to play things correctly.. in fact it all works beautifully... but at this point IF I use avs2dvd to convert my m2ts files (haven't tested others) it WILL revert back to 2/0 stereo in CCCP... is this normal... should I expect this? and if so for what reason... maybe I'm asking a really lame question but if thats true someone please answer it so I can enlighten myself and move on... thanks.
I don't know where CCCP puts it, but if you have ffdshow, you should have "ffdshow audio decoder configuration", which sets all the defaults for that, specifically under "mixer".
When I set this it stays set (eg, downmix to stereo, or disable the mixer if I want to have multichannel) until I change it manually, if that's any help. -
So if I'm reading your reply correct what you are saying is that if I have say 2 stereo computer speakers I can have it set up to downmix my input m2ts/avi/mkv/etc. files by selecting 2/0 stereo in ffdshow audio config settings? Which allows me to enjoy movies on my computer. HOWEVER when I want to convert with avs2dvd my selected choices in avs2dvd (worked out in another thread with MrC.) make it impossible to decode with the 2/0 stereo mixing scenario. So at this point I could just disable mixing and it will allow me to convert my movies... afterwards just tick it back to enable mixing which puts me back to my selected 2/0 setup (I notice no matter what config you select unticking the mixer makes it null) ??? hopefully that's not confusing to you... it is to me
I guess I'm just asking for some confirmation... Thanks!
Yes, though it depends on how the file is loaded in the AVS script.
A command like "DirectShowSource" will use the codecs set in Windows, like ffdshow. So if ffdshow is set to downmix, the script will have input stereo audio.
But there are other source commands, eg, ffmpegsource2, that directly interpret media files and so the Windows codec settings are irrelevant.
If you can edit the AVS file you can insert "info()" which will write the specs of the video and audio on the frame. -
I'm having the same issue. I set audio mixer config in FFDShow to 3/0/2 5 channel +LFE as recommended by the author of AVStoDVD. Then I go back later and look and it's set back to 2/0/0
Stereo.
I have Shark codec pack installed. But I don't see why anything would reset FFDShow settings. It's totally weird.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
If he's setting it in the program why would he instruct me to set it in FFDShow?
I don't get the reasoning.http://milesaheadsoftware.org/
I'm not sure, but I think it's something to do with conflicts in the past that MrC provided the option
to enable A2d to set it. Have you received any input from MrC on this ?
If you look at preferences/misc, you'll see the option. -
Just to clarify, A2D 2.2.6 is adjusting ffdshow mixer at runtime if:
- related option in 'Preferences'/'Misc' is on
- 5.1 AC3 encoding (not demuxing) is required
- ffdshow is installed
ffdshow reg key is changed only before audio encoding starts and reg key is restored to previous value when audio encoding ends.
This approach has one drawback: if QuEnc is selected as AC3 encoder, it requires GetChannel() to remap audio channels (small QuEnc bug). That's provokes a AviSynth error when video encoding starts (channels do not exist) because mixer is not yet changed. In that case, ffdshow mixer must be configured manually to 3/0/2+LFE.
In new 2.3.0 alpha release, ffdshow mixer is adjusted before video encoding starts and it is restored after audio encoding. In this way the QuEnc workaround is correctly managed.
Sorry if any misunderstanding was made.
Bye -
Thanks for the help. I guess 2/0 is the default its returning to right? I use 2 speakers so I just leave it alone now and toggle off mixing in ffdshow audio config whenever I encode my m2ts (which require the quenc setting for audio). After its done I have my settings back. I have also had luck with a temp setting of 3/0/2 +lfe, 3/2/1 6 ch, and the no mix option with these bd encodes. Does this sound like the right approach (for now without scripting) ? Is this better than changing the preferences/misc stuff ? When its adjusting what is it doing ? Selecting the proper ch config ? If toggling off the adjust in a2d pref's will handle my probs that'd be great.
Thanks for the info. I'll try some more runs.
One more thing I've noticed is that when I select no mixing and leave it there, after the encode of a2d it resets to the default (being no mixing)... which is fine because I use VLC and MPC-hc to watch shows... apparently they have their own setups... So my issues have completely gone away. My answer was to set "no mixing" in ffdshow audio config... so far I have seen no problems with my encodes and the setting remaining the same does not seem to affect my "viewing" experience on my computer...
Ffdshow - settings and version (svn?)
By Klemc in forum Software PlayingReplies: 0Last Post: 30th Jan 2011, 17:51 -
ffdshow settings
By Benjy in forum Video ConversionReplies: 3Last Post: 19th Mar 2010, 17:33 -
Ripbot - FFDSHOW settings aspect problem
By Melmac77 in forum DVD RippingReplies: 0Last Post: 23rd Dec 2008, 01:53 -
FFDSHOW Settings for MPEG2 Capture!
By Cauptain in forum Capturing and VCRReplies: 0Last Post: 18th Dec 2008, 08:55 -
Best video settings in FFdshow for xvid upscaling PC->TV?
By jimbop14 in forum Software PlayingReplies: 2Last Post: 27th Apr 2008, 08:38
