I have a Panasonic HD camcorder that outputs M2TS files. I'm looking for the best user friendly option here. I just want to convert them to smaller options to post on the internet. I don't mind paying up to $50 for software but I don't want to pay $600. I'm not doing that much. Most clips are small 4-10 minutes of my daughter playing softball. After converting them I may do some small editing in the sense of just removing a little bit of footage at the beginning or the end of the clip. So if someone could offer up some suggestions or point me to a how to I would appreciate it.
try converting to .mp4 with mediacoder or handbrake. they're both free. you will find other free tools to try in the tools section <--- also.
and welcome to the forum!--
Filesize = Running Time X Bitrate. Given running time is a constant, reduce the bitrate and you will reduce the filesize.
However, reducing the bitrate will impact quality to some degree. The lower the bitrate, the bigger the impact. You can balance this somewhat by reducing the resolution. It is a balancing act between all these factors.Read my blog here.
If you want to do any editing, you might want to look at Vegas Movie Studio HD
http://www.sonycreativesoftware.com/moviestudiohd
$40 and it'll do the basic stuff you require."Quality is cool, but don't forget... Content is King!" -
Is this better than Vegas Movie Studio 9?
Not necessarily better, but more suited to what you mentioned your requirements were in your first post. See the comparison chart. If you'll notice, the HDV/AVCHD option isn't checked in regular Vegas Movie Studio 9
http://www.sonycreativesoftware.com/moviestudiohd/compare
If you want to actually get additional features (DVD Authoring, BluRay, 5.1 audio), go with Vegas Movie Studio Platinum for $99
Cannot Format Specific Options in MKVmergeGUI
By PikachuCLS in forum EditingReplies: 2Last Post: 14th Apr 2011, 16:41 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
Should I use Virtualdub filtering options with a M2TS file ?
By rds11 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 15:50 -
encoding .m2ts with Megui. What's the best options?
By badreligionhead in forum Video ConversionReplies: 4Last Post: 23rd Sep 2009, 15:24 -
m2ts and ps3 issue/vegas export options aarrrggghhhh
By simoupnorth in forum Video ConversionReplies: 5Last Post: 28th Aug 2009, 00:26
