hi,
I have a really hard time editing hd and full hd clips in Sony vegas pro 9.
When i try to edit it just runs at 4-5 fps in the preview screen.
I edit .mov or avchd clips.
It runs fine when editing sd.
Computer specs:
CPU Specifications Manufacturer Intel Type Pentium D (Presler, 65 nm) Model SL9QB Clock Speed 3.4 GHz Front Bus Speed 800 MHz Cache 2x 2048 kB Socket LGA775 Stepping core C1 Maximum temperature 63°C Maximum power dissipation 95 W
Graphics card: ATI 4650 512 mb.
Motherboard:
¨Name: Rio (GA-8TRC410MNF-RH)
Type: µATX motherboard
Manufacturer: GigaByte
Ram: 2gb
More specs: http://support.packardbell.com/no/item/index.php?pn=PB35302691&g=1400
Dual core isn't fast enough for avchd or hd .mov avc clips in vegas (even though they may play fine in media players), even a highly clocked i7 can be a bit sluggish
Many people resort to using cineform neoscene , but even then a dual core will be a bit slow
You can try adjusting the preview quality lower to help a bit -
You can't edit avchd smoothly with a dual core in vegas, especially not with your system. It might have been "powerful" a few years ago, but not now. If you had a newer generation i5 dual core, then you might be able to
But perhaps your friend is using hdv , not avchd. There are different kinds of "HD video" , and MPEG2 is definitely less resource intensive -
http://www.kiva.org/about -
No way is your system fast enough. Time to either upgrade or hope Neoscene will permit you to edit with less CPU strain. The only drawback with Neoscene is that the resulting AVI files are going to take up a fair amount of disk space.
"Quality is cool, but don't forget... Content is King!"
Convert h264 to what for edit/slow computer
By krisbee in forum Video ConversionReplies: 1Last Post: 13th Apr 2011, 08:58 -
How do I edit and reauthor a recorded DVD on my computer?
By Baldrick in forum DVD & Blu-ray RecordersReplies: 3Last Post: 17th Nov 2008, 09:03 -
Possible hard disk and computer problems..
By SE14man in forum ComputerReplies: 5Last Post: 18th Oct 2008, 18:10 -
How to record dvd recorder then edit on computer
By CaptainChaos in forum Authoring (DVD)Replies: 8Last Post: 11th Jul 2008, 10:37 -
VHS to DVD OR HARD DRIVE TO EDIT WITH THE BEST QUALITY
By jakeconnor in forum Capturing and VCRReplies: 11Last Post: 9th Jul 2008, 21:04
