Hello guys,
BluRip has some predefined parameters for one pass encoding - but
What are the parameters for 2-pass encoding? Like fast first pass and good second, using the results from the first (duhu )
THanks!!
I haven't used the program, but generally a two pass encode consists of a first pass to assess bitrate requirements for a specific size output file. The second pass does the actual encoding, using the information gathered from the first pass. It will give you a set size of output file. Usually a single pass 'quality' type encode will give you a set quality, but little control over the output size.
thx - has anyone used the program - I think it's friggin' awesome - knowing how to use 2-pass to save some Gs would make it perfect!
x264, point of 1st Pass encoding?
By Sephisto in forum Video ConversionReplies: 50Last Post: 18th Apr 2012, 01:13 -
x264 encoding occurs too fast in pass 1
By codemaster in forum DVD RippingReplies: 5Last Post: 21st Sep 2011, 21:28 -
Why x264 is much slower in 2 pass ???
By cd090580 in forum Video ConversionReplies: 1Last Post: 15th Aug 2010, 08:45 -
x264 - new pass with different dimensions, is it OK?
By kurbads in forum Video ConversionReplies: 16Last Post: 5th Sep 2009, 06:57 -
Mencoder x264 2-pass in Windows
By blazerqb11 in forum Video ConversionReplies: 0Last Post: 22nd Nov 2008, 08:54
