    Feb 2002
    england
    i want to test some settings out on tmpg for making xvcd...
    what would be the ultinate movie to push the max bit rate to the limit (im using mvbr, max 800 min 500)
    i have used these settings for "the matrix" and got ok results (although it looks like a vhs copy)
    thanks people
  2. you want to see some great stuff a movie of 149 min encode it at only 539 mb size and look great
    Feb 2002
    england
    149 minutes huh???
    i dont think using my settings, that this will fit on a 700meg cdr....
    i will stick to 120 mins with the odd menu here and there
  4. well not with your setting but with my setting you will fit any movie on a 70 min cd 80 min cd for best quality
    Feb 2002
    england
    spill the beans then natcom....
    what settings do you use????
    if they are as good as you say they are in your other posts, then why not post them here????
    i have a couple of dvd's that will see if they work or not...
    xvcd encoding will vary, depends on the length of the movie and how much high motion there is so i would like to see how your settings wiegh up with a b****** of an encode
    i wait for ur next post
