I recently uninstalled AutoGK 2.55(cleaned out all registry traces) and reinstalled it, but not installing programs own xvid 1.21. I wanted to try newer 1.2.2 All my files kept coming out really undersized some 100mb on a target of 710mb.
I thought xvid(and later builds were compatible with AutoGK as according to FAQ? I use ESS chipset option only. K-Lite mega Codec Pack is installed too(I installed it without xvid set up and installed xvid codec separately. Still undersize issue. Later reinstalled(cleaned out registry again first) Klite Codecs with xvid included in install set up, still same issue.
My other question is: can the last version of VdubMod notably 1.5.10.2 be installed as an overlay in AutoGK's vdubmod folder without problems or conflict or does one just drop in exe file and VirtualDubMod.vdi only? Any help here is very much appreciated. Thanks guys.
You're just asking for trouble by using an XviD not included with AutoGK. Yes, the FAQ says it's OK to use any XviD unless using the MTK/Sigma option. But the FAQ hasn't been updated since ver. 2.40 of AutoGK. Didn't you used to get the right sizes when using v1.2.1 of XviD (the included one)? And now you don't with v1.2.2? Doesn't that tell you something?
Just to be sure, though, do you have a log for one of these undersized encodes? -
Perfectly correct! I was asking for trouble, but stupidly could not resist the challenge to try out new build trying to squeeze out extra quality. Now I have gone back to build 1.2.1 and everything is okay "bang on size." The compression test log for test using xvid 1.2.2 kept coming out 55.37%, but using xvid 1.2.1 it was 77.65%. The error was in the compression test which codec 1.2.2 was causing to go bonkers in AutoGK.
If it ain't broke don't fix it! -
Unfortunately AutoGK is not in development. Gordian Knot too? I also tried the unofficial "stable Xvid 1.2.2 & Vaq" which did produce a quality file despite undersize/lower bitrate as it has motion vector(4mv) enabled instead of turbo and a few other tweaks to facilitate encoding. For me using XP even after a clean format this build of xvid(standard or Vaq'ed is incompatible.
http://jawormat.republika.pl/xvid.html
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
uʍop ǝpısdn dןǝɥoǝpıʌ
By Squash in forum TestReplies: 10Last Post: 9th Sep 2010, 10:05 -
Megui - Undersized XVID file
By skaleton in forum Video ConversionReplies: 8Last Post: 21st Aug 2010, 12:09 -
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 14:37 -
XviD undersized files?
By Mdoodm1000 in forum Video ConversionReplies: 7Last Post: 24th May 2010, 21:22
