How Can I Convert Video to MKV with a smallest Size and?
Results 1 to 9 of 9
Use a lower video bitrate and that will make the file smaller. (And the quality lower) What program are you using to convert with?
And welcome to our forums.
I don't understand you brother!!
I have MKV movies, and I want to add image logo and mix subtitle without increase the size or effect the video quality.
so, how can I convert my movies to MKV files without change the size.
thanks for your time -
What do you mean you want to add an "image logo"? You want to overlay a permanent logo onto the video? You'll have to decompress, overlay, then recompress with the same bitrate. Recompression with a lossy codec will always involve some loss of quality. Subtitles can simply be multiplexed into the MKV file.
Yes brother, I want to add PNG image into the video.
and .. How can I mix subtitle in MKV simply (as you said)?.
Please, can you give the tools i need it?
You can add a subtitle track and an image file to the MKV container using MKVMergeGUI and MKVToolNix. The mkv file will grow by about the size of the image file.
If you want to overlay the image like a watermark or add hard subtitles then you will have to re-encode the video. You can keep the file size the same by using the same bitrate as the original (use mediainfo to find out what the current bitrate is) however the quality may dip. This is unavoidable.Read my blog here.
thanks brother but when I click on "MKVMergeGUI" and "MKVToolNix" I notice that the links or programs are the same!!!.
yeah brother, I mean I want to add watermark to the video, but how can I re-encode the MKV file, are you mean I need to re convert it? I did that , and i made the birate the same birate but the size is 1.2 gb. -
I have downloaded MKVMergeGUI and I have added a subtitle to the movie but when play it with GOM Player I can't see the subtitle?!!!!!.
Best compression, smallest size, highest quality?
By Sullah in forum Video ConversionReplies: 17Last Post: 12th Nov 2022, 11:48 -
Witch the best way to convert a BluRay Movie to MKV ( size DVD9 or else)
By siopilos in forum Blu-ray RippingReplies: 9Last Post: 12th Feb 2012, 21:59 -
Converting DVD's to best quality smallest size video file
By Thunderblaze in forum DVD RippingReplies: 1Last Post: 31st Dec 2011, 05:07 -
By Reckitt in forum Video ConversionReplies: 2Last Post: 27th Feb 2011, 09:39 -
How to convert the different video extensions to MKV ????
By eam_2005 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Oct 2008, 02:28
