I'm trying to play this type of video and were not able to...
Video
Format : xvid
Codec ID : xvid
Duration : 1h 21mn
Bit rate : 1 291 Kbps
Width : 624 pixels
Height : 256 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Resolution : 24 bits
Bits/(Pixel*Frame) : 0.337
Stream size : 755 MiB (94%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 21mn
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 37.4 MiB (5%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 24 ms
I have updated my ffshow, xvid codec, divx... Still doesn't improve. I'm able to hear the sound, but no video.
Cawv Yaaj
Cell Phone Shut Down During Video and Video Won't Play
By Chief4Life in forum Newbie / General discussionsReplies: 13Last Post: 17th May 2011, 22:26 -
Play All and Return to Same menu Problem
By cassy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2009, 20:14 -
FLV converting problem: video won't play
By dombi in forum ffmpegX general discussionReplies: 0Last Post: 1st Apr 2009, 03:51 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 16:44 -
First play problem.
By mpack in forum Authoring (DVD)Replies: 5Last Post: 6th Jul 2008, 06:19
