i bought a copy of new moon at wal mart, at midnight no less, may that was fun. heheh, what im trying to do is burn a copy for the van and ive tried fab it loads real slow. And when it finally loads it gives me a run error. It wont even load on dvd deycrypter, and rip it fails to. Any ideas or anyone know wheere i can get a decent freeware that will fix this or am i doing something wrong? any help appreceated see ya
				Results 1 to 10 of 10
	pretty much the same question every week. you need to wait until the rip programs are updated to take care of the newest protection schemes. if you are using the free version of dvdfab it could be awhile as it's updated after the paid version. --
	What I just don't understand is how they can have a new copy protection that won't work with existing software, yet the disc will play on any dvd player, even if its many years old.
 How the heck can that be??
	hehe that's what keeps the programmers rolling in the dough. at least dvd protection hasn't gotten as extreme as cd protection did at one time. they used a laser at one point to burn a hole through the cd at a specific sector that the software referenced. think you could burn a one sector sized hole in a disc? --
	As far as I know nobody has cracked some of the CD data navigation CDs like the Volkwagen/Blaupunkt ones. The protection on those really isn't part of the CD data though....it's inside the layers of the physical disc itself.
	You could try DVD43,it's freeware but might not be up to date for your DVD.
 There's also DVDfabPasskey.it's currently freeware and is probably more current than DVD43.Last edited by wulf109; 21st Mar 2010 at 14:32.
	I have both paid versions of anydvd and dvdfab the dvdfab beta 7.0.2.9 was said to be able to handle new moon, I'm running 7.0.3.0 and I get an error "102" and have to abort when its trying to burn. Also anydvd says that 6.6.3.0 is basically made for the new moon protection. So we just have to wait for another version?
 AnyDVD History
 6.6.3.0 2010 03 18
 - New: Again, improved handling of "files in use" during installation
 - New (Blu-ray): Updated decryption keys
 - New (DVD): Added support for new protections, e.g. "New Moon", R1, US
 - New: Improved compatibility of SetDisplayFrequency.exe with Windows 7
 - Added more programs to the list requiring "aggressive I/O mode"
 - Some minor fixes and improvements
 - Updated languages
 March 26, 2010
 DVDFab 7.0.3.0 Updated!
 - New: Language files.
- New: Main window is resizable and more readable on large screen now.
- New: Added "A/V Codec" page in Settings window, which allows user to set preferred decoder and encoder.
- Fix: Lots of small issues from V6.
 - New: Added support for a new copy protection as found on "New Moon" (US).
 - New: Added support for all known BD+ protection.
- New: Added chapter support, which means you can copy specific range of movie now.
- New: Added our own CUDA H.264 encoder. Note: If the video card is really high end, we recommend to enable both CUDA decoder and encoder for max speed. If the video card is not, we suggest to use CUDA encoder for BD25 output, and use CUDA decoder for BD5 and BD9 output.
- New: Added support for CoreAVC H.264 decoder to speed up copying.
- New: Improved BD9/BD5 and standalone Blu-ray player compatibility.
- Fix: A crash problem when opening certain Blu-ray discs, like "Precious".
- Fix: Backup disc cannot be played on Samsung standalone player.
 - New: Added new "Blu-ray to Mobile" option.
- New: Added HD file output for Xbox 360 and Playstantion 3.
- New: Added support for MKV file output. When using WD TV Live as player, it's a perfect match for Blu-ray backup.
- New: Added support for MKV chapter.
- New: Added support for "Display only forced subpicture".
- New: Added support for CoreAVC H.264 decoder to speed up conversion.
 Last edited by drifter666; 29th Mar 2010 at 12:07. Governments should be afraid of the people, not the other way around
  Anyone having issues with twilight new moon?By drifter666 in forum DVD RippingReplies: 7Last Post: 2nd Apr 2010, 01:16
  Constellation Dead?? Not going back to the moon??By Browncoat in forum Off topicReplies: 21Last Post: 25th Feb 2010, 12:40
  Apollo astronauts and the moonBy cyflyer in forum Off topicReplies: 9Last Post: 27th Mar 2008, 23:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
