  1. Posting this here, as it's more about scripting than encoding.
    I'm currently converting 4 seasons of a series for my omnia2 winmo phone. I have my standard settings/script, but want to make it universal, by allowing input datas (names/directories) to be inserted "once" in the beginning, then have the script insert the data as needed.
    Here's where I am so far...
    @echo off
    cd /d "C:\x264 tools\"
    %input% == F:\weeds\1-05\1.05.avs
    %output% == E:\weeds\season_1\1-1-05\1.05
    %chapters% == F:\weeds\1-05\chapters.txt
    %stats% == C:\x264 tools\stats\stats.stat
    @x264.exe --profile baseline --level 3 --slow-firstpass  --pass 1 --bitrate 1200 --vbv-bufsize 10000 --vbv-maxrate 10000 --ratetol 50 --stats "%stats%" --ref 2 --keyint 240 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --no-fast-pskip --bframes 0 --no-cabac --deblock -3:-3 --subme 6 --trellis 0 --partitions p8x8,b8x8,i4x4 --no-8x8dct --me esa --merange 64 --sar 1:1 --fps 23.976 --threads 2 --thread-input --output NUL "%input%"
    echo+
    @x264.exe --profile baseline --level 3 --pass 2 --bitrate 1200 --vbv-bufsize 10000 --vbv-maxrate 10000 --ratetol 1 --stats "%stats%" --ref 2 --keyint 240 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --no-fast-pskip --bframes 0 --no-cabac --deblock -3:-3 --subme 6 --trellis 0 --partitions p8x8,b8x8,i4x4 --no-8x8dct --me esa --merange 64 --sar 1:1 --fps 23.976 --threads 2 --thread-input --output "%output%.mp4" "%input%"
    echo+
    @bepipe.exe --script "import(^%input%^)" | faac.exe -b 128 - -o "%output%.audio.mp4"
    echo+
    @mp4box.exe -add "%output%.audio.mp4" "%output%.mp4" -chap "%chapters%" -itags "name=1.05: Lude Awakening:artist=Weeds:album=Season 1:album_artist=Weeds:created=2006:track=5"
    @if not errorlevel 1 del "%output%.audio.mp4"
    pause
    I've even tried %1, %2, %3, but both ways fail to load the files into x264.exe.
    Any advice greatly appreciated
    cheers
  2. Member Safesurfer's Avatar
    Mar 2004
    This link may be of help http://forum.doom9.org/archive/index.php/t-129415.html for some batch file examples.
    This quote from the link may help with setting up the x264 parameters.
    REM Video Conversion 2-Pass
    C:\Programme\megui\tools\x264\x264.exe --pass 1 --bitrate %3 --stats "%~dp1%~n1.stats" --ref 2 --mixed-refs --no-fast-pskip --bframes 3 --b-pyramid --bime --weightb --trellis 1 --analyse all --8x8dct --threads auto --thread-input --progress --no-dct-decimate --no-psnr --no-ssim --output NUL "%~f1"
    C:\Programme\megui\tools\x264\x264.exe --pass 2 --bitrate %3 --stats "%~dp1%~n1.stats" --ref 2 --mixed-refs --no-fast-pskip --bframes 3 --b-pyramid --bime --weightb --trellis 1 --analyse all --8x8dct --threads auto --thread-input --progress --no-dct-decimate --no-psnr --no-ssim --output "%~dp1%~n1_video.264" "%~f1
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
  3. thanks Safesurfer
    I saved that page, and will try tonight.
    Greatly appreciated.. thanks again
    cheers...
  4. Member Soopafresh's Avatar
    Jan 2004
    change to
    set input = F:\weeds\1-05\1.05.avs
    set output = E:\weeds\season_1\1-1-05\1.05
    set chapters = F:\weeds\1-05\chapters.txt
    set stats = C:\x264 tools\stats\stats.stat
    Your work will be easier if you don't use file or directory names with spaces in them, so consider renaming c:\x264 tools to c:\x264_tools
    "Quality is cool, but don't forget... Content is King!"
  5. thanks Soopafresh.. this is what I came up with from the link Safesurfer suggested.
    @echo off
    rem *** set Variables without extensions ***
    set input_file=F:\weeds\1-06\1.06
    set output_file=E:\weeds\season_1\1-1-06\1.06
    set stats_file=C:\x264 tools\stats\1.06
    set video_bitrate=1200
    set audio_bitrate=128
    set chapters_file=F:\weeds\1-06\chapters
    @cd /d "C:\x264 tools\"
    @x264.exe --profile baseline --level 3 --slow-firstpass  --pass 1 --bitrate %video_bitrate% --vbv-bufsize 10000 --vbv-maxrate 10000 --ratetol 50 --stats "%stats_file%.stat" --ref 2 --keyint 240 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --no-fast-pskip --bframes 0 --no-cabac --deblock -3:-3 --subme 6 --trellis 0 --partitions p8x8,b8x8,i4x4 --no-8x8dct --me esa --merange 64 --sar 1:1 --fps 23.976 --threads 2 --thread-input --output NUL "%input_file%.avs"
    @echo+
    @x264.exe --profile baseline --level 3 --pass 2 --bitrate %video_bitrate% --vbv-bufsize 10000 --vbv-maxrate 10000 --ratetol 1 --stats "%stats_file%.stat" --ref 2 --keyint 240 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --no-fast-pskip --bframes 0 --no-cabac --deblock -3:-3 --subme 6 --trellis 0 --partitions p8x8,b8x8,i4x4 --no-8x8dct --me esa --merange 64 --sar 1:1 --fps 23.976 --threads 2 --thread-input --output "%output_file%.mp4" "%input_file%.avs"
    @echo+
    @bepipe.exe --script "import(^%input_file%.avs^)" | faac.exe -b %audio_bitrate% - -o "%output_file%.audio.mp4"
    @echo+
    @mp4box.exe -add "%output_file%.audio.mp4" "%output_file%.mp4" -chap "%chapters_file%.txt" -itags "name=1.06: Dead in the Nethers:artist=Weeds:album=Season 1:album_artist=Weeds:created=2006:track=6"
    @if not errorlevel 1 del "%output_file%.audio.mp4" "%stats_file%.*"
    @echo+
    pause
    or setting up and calling a script as needed:
    1.06.bat=
    @echo off
    call "C:\x264 tools\scripts\iPhone\480x320.bat"
    pause
    480x320.bat=
    @echo off
    @echo+
    @echo+
    @echo+
    @echo+
    Then I can set up 3 or 4 batches a night, then call with another batch - just need to remove "pause" from each individual script, or it will pause after each
    run.bat=
    @echo off
    call "F:\weeds\1-06\1.06.bat"
    @echo+
    call "F:\weeds\1-07\1.07.bat"
    @echo+
    call "F:\weeds\1-08\1.08.bat"
    @echo+
    #call "F:\weeds\1-09\1.09.bat"
    @echo+
    pause
    I see what you mean by spaces though, as my input used to be "*\weeds - separated\*\*". I tried the linux way with "/ /" for spaces, but didn't like that
    But "x264 stuffs" seems to be fine... after putting in quotes
    cheers, and again, a huge thanks.. I'd still be fighting a week down the road otherwise
  6. Member Soopafresh's Avatar
    Jan 2004
    Good job, you figured this stuff out quickly
  7. Thanks
    I goofed, but caught it before my next video... everything would've been tagged the same otherwise :doh!:
    1.07.bat=
    @echo off
    rem *** set variables without extensions ***
    set input=F:\weeds\2-01\1.07
    set output=E:\weeds\season_1\1-2-01\1.07
    set fps=23.976
    set stats=C:\x264 tools\stats\1.07
    set chapters=F:\weeds\2-01\chapters
    set title=1.07: Higher Education
    set artist=Weeds
    set album=Season 1
    set created=2006
    set track=7
    set comment=
    pause
    480x320.bat=
    @echo off
    @x264.exe --profile baseline --level 3 --slow-firstpass  --pass 1 --bitrate 1200 --vbv-bufsize 10000 --vbv-maxrate 10000 --ratetol 50 --stats "%stats%.stat" --ref 2 --keyint 240 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --no-fast-pskip --bframes 0 --no-cabac --deblock -3:-3 --subme 6 --trellis 0 --partitions p8x8,b8x8,i4x4 --no-8x8dct --me esa --merange 64 --sar 1:1 --fps %fps% --threads 2 --thread-input --output NUL "%input%.avs"
    @echo+
    @x264.exe --profile baseline --level 3 --pass 2 --bitrate 1200 --vbv-bufsize 10000 --vbv-maxrate 10000 --ratetol 1 --stats "%stats%.stat" --ref 2 --keyint 240 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --no-fast-pskip --bframes 0 --no-cabac --deblock -3:-3 --subme 6 --trellis 0 --partitions p8x8,b8x8,i4x4 --no-8x8dct --me esa --merange 64 --sar 1:1 --fps %fps% --threads 2 --thread-input --output "%output%.mp4" "%input%.avs"
    @echo+
    @bepipe.exe --script "import(^%input%.avs^)" | faac.exe -b 128 - -o "%output%.audio.mp4"
    @echo+
    @mp4box.exe -add "%output%.audio.mp4" "%output%.mp4" -chap "%chapters%.txt" -itags "name=%title%:artist=%artist%:album=%album%:created=%created%:track=%track%:comment=%comment%"
    @if not errorlevel 1 del "%output%.audio.mp4" "%stats%.*"
    @echo+
    Much better now...
    cheers v
