Searched the forums for an answer, couldn't find anything. if anyone knows of a relevant thread, i'd be glad to know of it.
Im a n00b at capturing video, so i assume i have much to learn.
Using windows, Adaptec Veoh! and a VCR to capture video from the vcr. Software used to capture: Video Lan Client. I get a transport stream which plays fine in vlc, but will not play in any other player. all settings were at default when i captured, seem to work fine for the capture. The video is mpeg2 capture, the audio is LPCM, this is according to vlc. If i try to encode using autogk, it cant find the audio file. Media Coder produces a file with video and no audio. I assume there's some sort of conversion tool out there perhaps which can convert my transport stream into an mpeg2 file without any more re encoding? from there i could encode it to which ever format i wished. i hope? I don't understand this stuff, i just need a bit of help. what am i missing here?
edit: Elecard Stream Analyzer says that the audio codec is AC3, as does autogk (says its private ac3 stream, but still cannot find or decode it)
Results 1 to 1 of 1
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
Need to find a program that converts to MPEG-2 Transport Stream
By rprice806 in forum Video ConversionReplies: 2Last Post: 20th Oct 2009, 12:10 -
Re-encoding MPEG2 Transport Stream (.ts) file
By kary.sharma in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 04:01 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06 -
Encode to Transport Stream (.TP)
By HansBeekman in forum DVB / IPTVReplies: 21Last Post: 24th Jul 2007, 17:45
