i have pinnacle pctv tuner card which i use to record tv shows and the file gets saved in mpeg2 format which i write it on dvd using nero visoin 4 and make a dvd video disc
the thing is i want to add subtitles to my files....like the translations u see in the movies...the text that come below....i want to do that
i dont have any subtitle files so i will be manually typing each and every line.....and i want the videos to be in mpeg2 format,...dont mind changin the format but cannot compromise on quality
pls suggest me any nice software or any tool that has easy interface which allows to do me all these functions
thanx
	Use a subtile software like subtitle workshop or subtitle edit and make srt subs. They should be able to load the mpeg2 (if not install ffdshow).
 Then I don't know if nerovision supports srt...but you can always use free tools like dvd flick, load mpeg2 and srt and make a dvd with switchable subtitles.
	You can author the DVD using ConvertXtoDVD - just put the mpeg2 file and the srt file in a folder and select the video file in ConvertXtoDVD - it will automatically pick up the subtitle file (which should have the same name as the video file. There are other programs around that will do it but these days VSO is the only authoring program that I use. SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
  How to Add Text Effects and Unicode Characters to MPEG-4 SubtitlesBy PBear in forum User guidesReplies: 9Last Post: 20th Sep 2012, 10:15
  Manually sync text file with videoBy druucifer in forum SubtitleReplies: 1Last Post: 16th Aug 2011, 13:57
  Add text to MKV or AVI files...Without loss of quality...By jaseemkannur in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 05:36
  How to add text and still pics to a video using VirtualDub 1.9.9?By mileena in forum Newbie / General discussionsReplies: 5Last Post: 8th Nov 2010, 11:46
  Add Text to DVD & CD To Display On PlayerBy drtalk in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2008, 14:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
