My leadtek capture card got it's audio when using the tuner from a 4pin connector cable. You had to run the cable from the card to the cd in on the motherboard or aux in on a sound card. I'm looking around for a new card now and have some questions. Is that how most capture cards work with audio? Do some capture cards get audio from the RF tuner connection? I would like to know mostly because I want to use my motherboard's intergrated sound and there is only so many connections for that. Thanks for any help....
You need to get more specific on type of tuner or capture card. They vary. Newer digital cards can transfer audio over PCI. Others need to use line in, CD in, Aux in direct connections.
http://www.kiva.org/about
Hauppage or other QAM support TV tuner cards and EQAM
By bithead9 in forum Media Center PC / MediaCentersReplies: 1Last Post: 23rd Apr 2009, 03:22 -
Are computer tv tuner cards ever counted in tv ratings?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2008, 20:13 -
Opinions on Fusion HDTV Tuner Cards
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2008, 12:02 -
HDTV Tuner Cards with outputs
By jbartosh in forum Capturing and VCRReplies: 0Last Post: 24th Jun 2008, 16:49 -
Need new (cheap) capture solution-what to get? Are TV tuner cards any good?
By wickeddvine in forum Capturing and VCRReplies: 1Last Post: 16th Jun 2007, 09:50
