After installing ripbot latest version , it requires FFDShow settings..
Where are few explanations about these kind of settings ??
there is a tutorial ???
I'm a newbie so....hope you understand me...
There are too many settings to do and I am not a specialist ..
I do not know what to tick / check and what not
who can guide me?
Thanks for help !!
You shouldn't have to do much of anything with ffdshow just for RipBot use.
But there are some help files here: http://www.ffdshow.info/ Click on 'Support' just under the ffdshow logo. -
Thanks redwudz , but your links do not much helped me !!
(( There is NO connection with my problem
I repeat : After installing new version of Ripbot this one requires to reinstall ffdshow and haali . I've installed Haali without problems ,and start with instaling ffdshow...everything's OK up to the end when ffdshow ask me to make 4 kind of settings regarding audio , video , and other two...that implies a lot of checkings , a lot of options to be selected , a.s.o.
If I check all 4 options ,other windows appear with lots of options and I don't know what should I select..
Here is my problem : what kind of options should I select ???
because if I do not select nothing , the soft do not install
Thanks for kindness !!
here is :
Ffdshow - settings and version (svn?)
By Klemc in forum Software PlayingReplies: 0Last Post: 30th Jan 2011, 17:51 -
ffdshow settings and conflicts
By VicSedition in forum Newbie / General discussionsReplies: 13Last Post: 31st Mar 2010, 16:55 -
Ripbot - FFDSHOW settings aspect problem
By Melmac77 in forum DVD RippingReplies: 0Last Post: 23rd Dec 2008, 01:53 -
FFDSHOW Settings for MPEG2 Capture!
By Cauptain in forum Capturing and VCRReplies: 0Last Post: 18th Dec 2008, 08:55 -
Best video settings in FFdshow for xvid upscaling PC->TV?
By jimbop14 in forum Software PlayingReplies: 2Last Post: 27th Apr 2008, 08:38
