Hi,
I have been searching for a video transcoder with a video bit rate more than 50000kbps, but most of it has a max of 20000k. I know probably some of the video codec and container format might have some limitation. Here is the video profile that i wish i could get it transcoded for my project. Any idea where could i get a transcoder(s) that could do the below profiles?
H.264 - Main profile and high profile, L4.1, 50000kbps (video bit rate)
MPEG2 - Main profile, High, 80000kbps (video bit rate)
VC 1 - Advance Profile, L3, 45000kbps ( video bit rate)
AVS - Jizhun profile, 6.0, 4.0, 2.0 , 20000kbps (video bit rate)
Thanks.
TMPGEnc Plus can go as high as 80,000 kbps with SD material. You have to switch to high profiles though. HCEnc can too.
Digi-Beta SD is 90 Mb/s. SDI is 270 Mb/s*. What is your source?
* SMPTE 259M uncompressed 8/10 bit 704x576 4:2:2 sampling.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thank you guys. The transcoding was great.
Btw, i need some clarification from some of you (the guru
I have a question and i found in most of the forum that a blu-ray dics (BD) could only do a video playback when there is a HDCP BD ROM, HDCP graphic card and HDCP HDMI and DP monitor.
But i have tried to play the BD content using a HDCP stuffs except that i use the VGA of the HDCP compliance monitor. The BD video content was playback beautifully. So my question is, is that possible using VGA instead of HDMI / DP in HDCP environment which sound contradict.
Besides that, are all BD content is protected? hmm... -
Direct play to VGA is not allowed for HDCP content. You need an authenticated HDCP connection over DVI-D or HDMI to play protected content above DVD 720x480/576 resolution.
The author of the Blu-Ray disk has several options for protection. One option is HDCP off.
http://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_ProtectionRecommends: Kiva.org - Loans that change lives.
DVD at high bit rate - Blocky & grainy on big screen
By nharikrishna in forum Authoring (DVD)Replies: 8Last Post: 27th Oct 2010, 03:46 -
Question about way too high bit rate video from digital camera
By jimdagys in forum Video ConversionReplies: 12Last Post: 16th Dec 2009, 16:14 -
DVD on Sony Walkman X, "SP" template but high bit rate
By dch888 in forum DVD RippingReplies: 1Last Post: 6th Dec 2009, 16:19 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
HD DVD's conversion the high bit rate DVD...can it be done?
By Crankshaft100 in forum Blu-ray RippingReplies: 3Last Post: 26th Nov 2008, 18:53
