Results 1 to 14 of 14
    Oct 2009
    Germany
    Hello guys,
    after demuxing a BD with Ripbot and pressing "START" the status says: "Please Wait... Initializing..." but nothing happens - until I press "cancel" - so the programm does not crash but some thing stops it from processing.
    Did anyone have the same problem (and probably) found a solution?
    Thanks in advance
    info.txt reads:
    221278
    23.976044
    48000
    2
    442998784
    1920
    800
  2. Member wulf109's Avatar
    Jul 2002
    Define "forever". Your using a slow computer,it could easily take 30 minutes to demux on your system.
    Oct 2009
    Germany
    I don't mean demuxing - after demuxing as I press start is usually takes a few seconds of "Please Wait... Initializing..." and then the % Counting starts. Now I waited 1h and nothing happens...
    Aug 2004
    I have had numerous problems with RipBot using ANSI characters like å,ä,ö,ü in filenames or pathnames.
    Oct 2009
    Germany
    Thanks for the hint - but there are no ANSI characters in any of the pathes used...
    Now I played around a little and I found out that Ripbot only hangs when I try to embed AC3 Audio!
    If I switch it to 5.1 CT AAC-LC (or anything else) it starts!
    What component do I have to reinstall or reconfigure? Source is DTS-MA (but the corresponding WAV-File was created!)
    Jan 2009
    Japan
    I just tried to convert a BD with Handbrake and it works also. All you have to do is point to the correct M2TS file. It doesn't work on BD that have the movie spread out over all the files on the BD though. And it doesn't take 5-8 minutes to gather the details about the movie your about to code.
    Oct 2009
    Germany
    Thanks for the advice - but I really would love to get RipBot running again - if it runs, the tool rocks!
  8. Set audio normalization to OFF
    Also How high is cpu utilization during "Please Wait... Initializing..." phase?
    What cpu do you have?
    Oct 2009
    Germany
    I have a Q6600 at regular speed.
    lately I suspect ffdshow is no longer running well on my machine - reinstall does not help. Is there a way to do a complete uninstall / reset of all ffdshow settings and then start over (I mean except nuking vista back to zero?)
    Thanks for the help!
  10. Uninstall ffdshow in the same way how you uninstall any other application.
    new ffdshow is here
    http://sourceforge.net/projects/ffdshow-tryout/files/
  11. Member wulf109's Avatar
    Jul 2002
    Are using Ripbot 1.15.1 ? Many people are reporting problems with this latest version. Revert to 1.15.0
    Oct 2009
    Germany
    I tried ripbot 1.15.0 and 1.15.1 - same problem - I uninstalled - and reinstalled ffdshow (from the tryout folder) - did not change anything.
    I tried BluRip with the crop input mode set to DirectShow - processing fails at crop (very quick test) - then I switched to FFVideoSource - and it works.
    so I am sure it is not a RipBot problem - but still I have now way of fixing or even diagnosing the source of this problem.
    Any ideas?
    Oct 2009
    Germany
    Ok - here is how I got it running again (at least for the quick test with the BluRip Crop):
    Uninstall ffdshow
    run Registry-Clean of Gralry Utils
    Install latest version of ffdshow (3326)
    and it works again!
    Thanks to everybody who helped!!
  14. Member wulf109's Avatar
    Jul 2002
    Have you tried BDrebuilder?
