Hi Guys, New here. I am running Ripbot 1.15.1 and for the past 2 encodes i've had problems. The first one was a BSOD and the other was an error that read x264_x64.exe as stopped working. I am running windows 7 64 bit with an intel i7 processor 920 OC 6GB ram. I have successfully encoded my last 9 movies but for some reason the last 2 have failed during the 2nd pass. I was able to reach 65% on my last movie 2 pass and it stopped and popped up the above error.
My CPU is about 70% temp at full 100% load which was the case with the other encodes that I did before but never had this problem. I haven't installed anything in since the successful encodes.
Any ideas what I should do?
Switch to BDrebuilder,it has fewer bugs and is even a little faster than Ripbot. I've seen quite a few complaints about version 1.15.1,you could try reverting to 1.15.0,but do a complete un-install of 1.15.1 first.
I had a problem with 1.15.1,it interfered with MultiAVCHD and I could only get MultiAVCHD working by un-installing 1.15.1
Where you using W7 on your successful encodes?Last edited by wulf109; 18th Mar 2010 at 19:54.
Does BDrebuilder encode to mkv? Thats what i want to accomplish here. Ripbo again failed. I unisntalled and reinstalled and crashed on 2nd pass. I was using Windows 7 ultimate on the successful encodes. I'm about to throw away ripbot out the window.
Isn't there another software that i can us to mux the audio core that i extracted and the x264 video file that TXmuxer generated? Will BDrebuilder allow you to encode these files like ribot
Thanks -
Sorry,BDrebuilder only converts to a BlueRay/AVCHD directory from BR files(m2ts)
Try MakeMKV, it might do what you want,create MKV files?Last edited by wulf109; 18th Mar 2010 at 21:42.
tsMuxeR.exe has stopped working
By stblob in forum Authoring (Blu-ray)Replies: 8Last Post: 7th May 2011, 13:24 -
Need help-Been using ripbot for sometime now....it has stopped working.
By clefus in forum Blu-ray RippingReplies: 3Last Post: 13th Jan 2011, 11:42 -
Wavi.exe stopped working
By jcknecht in forum Blu-ray RippingReplies: 11Last Post: 1st Jan 2011, 15:24 -
x264.exe has stopped working
By newpath in forum Video ConversionReplies: 6Last Post: 17th Jul 2009, 16:42 -
%APPNAME%.EXE has stopped working
By beardedboss in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th May 2008, 03:23
