Hi all-
I've been trying sometime now to convert some screen capture of some software I made to flv format but it seems like what ever I try, the resulting flv file is grainy and the screen capture AVI file is always clean. Is it possible to produce an flv file that isn't grainy? To capture, I've been using both Screen VidShot and CamStudio and for conversion both WinFF and Riva. I played around with using different Codecs and different bit rate and resolutions and frame rates but I invariably produce grainy flv files. Also when I first open the flv it seems crisp but as the video plays, the quality starts to degrade. Any help would be much appreciated.
Thanks,
Daniel
FLV1? I'm using Flash CS4 targeting Flash Player 10. Does that help answer your question?
Daniel -
Can you choose a different video codec? flv can contain flv, on2 and h264 video. on2 and h264 is much better than flv.
(I only use free tools so I don't know any settings in flash cs4). -
I'm thinking the bit about CS4 is off topic anyway-- in flash, you can embed the player in your application so the end result is a bit more integrated than using a stand alone player. OK back on topic --
Wow I didn't know that. Flash player 10 can take files other than flv format such as on2 and h264. So now it looks like my job is to use the above mentioned tools and go from AVI to on2 or h264. Great. I can't wait to start. I assume the default settings should suffice as far as frame rate, bit rate etc. Perhaps you can direct me to a guide to answer these questions. Thank you so much. I'll be sure to post my results
Daniel -
Works like a charm!! Thanks a million. Looking so pro thanks to your direction.
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 08:05 -
FFMPEG AVI to FLV Converting Help!
By sp0oon in forum Video ConversionReplies: 6Last Post: 20th Jan 2010, 12:48 -
converting avi to flv
By ghaida in forum Video ConversionReplies: 0Last Post: 19th May 2009, 04:36 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 23:09 -
Converting flv. to avi.?
By Hikari112 in forum Newbie / General discussionsReplies: 7Last Post: 7th Oct 2007, 11:41
