have anyone ever burn a movies to vcd using 90mins or 99mins cd-r before?
is it good ? i would like to know that.
i burned rush hour 2,shaft,swordfish and caveman's valentine(had to do a little trimming) using 99 min cds with a liteon 32123S. so far so good.
It works just like a regular 74 or 80 minute CD-R. You just need to have a burner that can burn it, and set the overburn option in Nero. Most, but not all, DVD players will play the 99 min CD-R's.
Similar question :
Nero doesn't recognize the 90 minutes cd as 90 minutes, just as 80 minutes (my cyberdrive 038D is officially able to burn 90 or 99 minutes cds) - still no problem just using the overburn feature of nero ?
i have no clue what happens whlie overburning (esp. more than the regular 2-3 minutes) and i've heared that overburning can also damage the writer, not cd only (though on the other hand in this case it would not be real overburning as the cd is 90 minutes)
somehow confused ... -
90 and 99 minute CD-Rs all report 80 minute capacity, you cannot make the CD-R report any larger number. Check the CD-RW list on this web site if it can burn 90 or 99 min. CD-Rs. You will most likely get an error message if your burner can't do it during the overburn process.
Thanks a lot,
just burned a 85 min. VCD, played well on my noname DVD.
for all facing the same problem, enabling the overburn feature in neros advanced settings and ignoring the overburn message works (at least on my cyberdrive 038D) does the job.
How to upload more than 10 min on YOUTUBE
By 3thman in forum Video Streaming DownloadingReplies: 5Last Post: 6th Mar 2010, 14:59 -
Why does it only convert 15 min. worth?
By woodcliff in forum ffmpegX general discussionReplies: 1Last Post: 12th Dec 2009, 20:11 -
Last few min of AVI being cropped out
By Mr_Del in forum Video ConversionReplies: 1Last Post: 15th Mar 2009, 08:59 -
4 min movie conversion
By Tahir Ramzan in forum Video ConversionReplies: 2Last Post: 3rd Jan 2009, 00:46 -
Replaying a 10 min section
By elute96 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 14:03
