I have a h264 encoded .mp4 file that is about 20 minutes long. At the 13 minute mark there is a sort of stutter or hiccup and for the rest of the video the sound is about 1 second behind the video. How can I snyc the audio with the video for just the last 7 minutes? Thanks.
Generally, you would have to split the file into two parts and correct the sync error, then join them back together. That's a short enough file that I might convert it to a lossless format first, do your editing/sync correction, then re-join, then re-encode to H.264.
H.264 is not editor friendly and you would have to cut it at a keyframe or you will have worse sync problems. Highly compressed formats tend to have widely spaced keyframes.
Easier, IMO, to convert to lossless like Lagarith or HuffyUV then re-encode after the repair.
But others may have better advice.
Ok. I just converted my Video to xvid with fantastic results. What is the best way to go about fixing this now that it is a more edit friendly format. Thanks
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
No Audio in Part of Video
By wingspar in forum EditingReplies: 2Last Post: 31st May 2011, 16:43 -
converting the audio part of a video (for xbox)
By vidm in forum Video ConversionReplies: 6Last Post: 28th May 2010, 23:16 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36
