Hi,
Will Apple Studio Pro work on a g4 powerbook?
Thanks, Jerry
It should work fine without a problem, as long as you have a valid serial number. I am working in Apple DVD Studio Pro 1.0, and it works well on my G3 iMac in full OS 9. I was shocked! I can author the DVD content, have it author a compliant DVD1.0 image file, and burn the image file to CD-R (as long as the project is under 700mb) in Toast. I've made three of these miniDVDs this weekend ... now I just need to take them to work on Monday to test them in a software DVD player! I may stop by Kinko's and try it there if I can tear myself away from the software! I can't leave the house! Theres so much more to learn!
Hi,
Thanks for the response, I have an Imac DV and the Apple site says Studio Pro requires a G4. I was thinking of getting another powerbook but if I can use my Imac it would be better.
Thanks, Jerry -
Yes, the statement it "requires a G4" processor put me off experimenting for awhile .. then I actually tried it! It worked.
Now keep in mind this is the very first version of DVD Studio Pro, so thats probably why it works. This is not the OS X version I speak of.
Also theres a learning curve there -- Nothing is obvious, for example, where to start first!
Avid Studio vs. Sony Vegas Pro/Studio
By HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06 -
Cannon Mv5i and apple pro
By cashley in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2010, 15:01 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Is Apple pro and regular laptop the same ????
By mol3000 in forum Off topicReplies: 6Last Post: 21st Aug 2007, 18:43 -
Premiere Pro to Apple DV Stream?
By JoNuggs in forum Video ConversionReplies: 3Last Post: 30th Jul 2007, 10:52
