  1. I am getting really annoyed with one of the MKV movies I am trying to play on my PS3. I have no clue what PS3 does not like about it. Here is what I have:
    Output from MediaInfo:
    Format : Matroska
    File size : 7.95 GiB
    Duration : 2h 10mn
    Overall bit rate : 8 717 Kbps
    Encoded date : UTC 2007-08-08 17:53:58
    Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Muxing mode : Container profile=Unknown@5.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 10mn
    Bit rate : 8 160 Kbps
    Nominal bit rate : 8 329 Kbps
    Width : 1 920 pixels
    Height : 816 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 25.000 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.208
    Stream size : 7.44 GiB (94%)
    Writing library : x264 core 56 svn-667C
    Encoding settings : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=8329 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=187687,195786,b=0.15 / aq=1:0.3:15.0
    Language : English
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 2h 10mn
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 358 MiB (4%)
    Language : English
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Language : English
    I used Xvid4psp to change the container to mp4 copying the video stream but the PS3 plays only audio. I thought that this is the high profile 5.1 problem so I used tsMuxeR to change the level to 4.1 with no success still no video on my PS3 (only audio). Is there anybody who can help me with this saying what PS3 is not liking about this particular video stream.
    Any help is appreciated.
    Apr 2004
    Miskatonic U
    I have seen this before on my PS3, and I believe the issue is in fact the audio. I don't think the pS3 handles AC3 in an MP4 container very well. Try using the m2ts container (much higher overhead, unfortunately), or converting the audio to AAC.
    Read my blog here.
  3. I converted the audio to AAC with no difference, moreover I have audio I have no video. This is only an example of the file I am having problems with. Here is the file after conversion to 4.1 and with AAC audio:
    MediaInfo:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 7.77 GiB
    Duration : 2h 10mn
    Overall bit rate : 8 526 Kbps
    Encoded date : UTC 2010-03-16 22:29:41
    Tagged date : UTC 2010-03-16 22:29:41
    Video
    Format : AVC
    Format profile : High@L4.1
    Codec ID : avc1
    Duration : 2h 10mn
    Bit rate mode : Variable
    Bit rate : 8 329 Kbps
    Maximum bit rate : 23.3 Mbps
    Height : 816 pixels
    Frame rate mode : Constant
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Bits/(Pixel*Frame) : 0.213
    Stream size : 7.60 GiB (98%)
    Title : Imported with GPAC 0.4.6-DEV (build 1)
    Tagged date : UTC 2010-03-16 22:35:21
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 2h 10mn
    Bit rate : 192 Kbps
    Maximum bit rate : 288 Kbps
    Channel positions : Front: L C R, Rear: L R, LFE
    Stream size : 177 MiB (2%)
    Encoded date : UTC 2010-03-16 22:35:15
    Audio plays fine no video.
    Feb 2008
    Twin Peaks
    Try converting your file using handbreak and see if it will play it then.
    Jan 2007
    b_pyramid=1
    PS3 does not like b-pyramids. Pretty sure most BD players don't
    also, AC3 audio is fine on the PS3.
  6. Thank - do you know what I should change the b_pyramid to =0 or just erase this from the CLI
    Jan 2007
    The default for b-pyramid is 0, I believe, but just to be on the safe side I'd specify that. Also, keep an eye on the level and the video bitrate - level should be 4.1 (as you've already surmised) and bitrate I'm not entirely certain - try the "What is -> Blu-Ray" link on the top left.
    So, yeah, you'll need to re-encode. Either that, or you can install PS3 Media Server on your PC and stream it to the PS3. Keep in mind that you need pretty good processing power and connection to stream HD content, and you can't really rewind or fast-foward
  8. Thanks - I will try that. In the mean time I was using mkv2vob with the h264 which did the job but needed to re-encode.
