  1. Hi,
    Firstly, sorry if this is in the wrong place, please advise where this should be posted.
    I have been given a late chance to get onto a course due to a late pull out. As a project to get onto the course, I need to produce a short (3-5mins) highlight DVD of an upcoming sporting event. I have a DVD recorder (Sony RDR-HXD890). My plan is to record the event onto the DVD recorder, burn this onto a DVD, edited this on my PC and then burn the disk to be sent in.
    My questions are as follows:
    1) What disks should I use?
    2) What software should I use? As well as editing out the highlights, I may need to add text, screens with stats in etc.
    3) Are there any free software/software with trial periods that I could use and where can I get them from?
    4) If I burn the disk on my PC to be submitted, can I 'finalise' it on my DVD recorder and how do I do this on my PC?
    5) Any tips and is my plan feasible?
    Sorry for the big post, but this is a big chance for me and I have been given short notice.
    Cheers
    2) I think Mpeg Video Wizard DVD would be something to try. Free trial.
    1. Good discs. Verbatim or TY. Learn more about blank DVDs.
    2. Womble MVW.
    3. Womble MVW from here.
    4. Don't do that -- it will suck.
    5. Record with DVD recorder. Do this to rip. Do this to edit. Author in whatever -- Womble is fine, I guess, since you're not interested in buying good software. (And if you are, use DVDWS2 for $50).
    Don't turn in crap. Good luck.
  4. Baldrick and lordsmurf, thanks a lot for your replies and advice; very much appreciated. Not sure if you'll have any interest in how I get on, but I will reply to this thread to let you know (may help another user like my self).
    Cheers again!
