i need help using this to make a vcd.i have tried it once and the video looked like crap.the main reason im using this cause i can use the subs off the dvd.anytime there is a lot of movement or a little you can see lines in the movie.does anyone know how to fix this?
Results 1 to 16 of 16
Hello, I tried to download DVDx 1.7 but the url in the tools section is broken. Can you give me another url?
hi,
Try to use DVDx with Some other encoder like CCE or Panasonic Mpeg encoder. I use CCE with DVDX it is great and have no problem so far and it is bettee than the Direct DVDXto VCD encoding. or else use DVD2AVI and TEMPengc once of the best method's and both are free.
Baskaran -
hi,
no it is not. you can get a demo ware from www.cinemacarft.com
Baskaran -
when i have the panasonic encoder how en where must i install it .
in the plugins ???? -
hi,
if you have the panasonic encoder plugin for Adobe. Please copy the plugin file to the DVDX installed directoy then when you start the DVDX program it will show it in the bottom part where it list the external encoders
Baskaran -
how do i get the pansonic plug in to work?all it does is encode 2 frames.why wont it do more?i have it set to do the whole movie.
anyone know? -
does anyone know how to get the pansonic plug in to work?all it does is encode 2 frames.why wont it do more?i have it set to do the whole movie.
also is the other plugin better?
need help asap.
DVDx 1.8/1.8a will not work with Panasonic plugin, version 1.8 may work 1 out of 100 times (say, on a fresh, clean Windoze install, otherwise it will most often crash), version 1.8a will not work at all, no way.
If you want to use Panasonic plugin use it with DVDx 1.6, it works 100% with good results (but you will suffer from blinking subtitle bug in DVDx 1.6, but this is not really a big deal). During installation when asked for Premiere plugin folder just point to DVDx folder and off you go. Settings which worked best for me were:
- noise reduction: weak or medium
- video filter: adaptive, medium level
- color tone correction: TV (I use TV to watch VCD movies, not PC)
It seems that Panasonic plugin, while providing overall very nice quality, darkens the output .mpeg a bit, therefore I usually turn on luminance filter in input options of DVDx, gain/offset of 150/50 to 200/20 worked best when watched on big screen.
Sinc I don't make SVCDs I only use this combo for DVD to VCD work. -
yea i couldnt get it to work with 1.8 so i went out and found 1.6 and it only does 2 frames of the movie.i cant figure it out.
i have dvdx 1.8 and the panasonic encoder works fine for me, at first it
kept crashing i found out this was down to the rgb24 setting i changed this to rgb 32 (in output settings)and away it went done american pie 2 (2 dics's)and scary movie 2 (1 disc) in one day without a hitch in vcd format. also dont tick multi pass for the encoder this will also cause a crash, also in the input settings i would advise u put the "save your dvd drive" setting to 700mb location hard drive this will ensure ur dvd dosnt over heat, i had it set to 10mb and my drive would stop reading the disc half way through the encoding everytime. this was done on windows xp so dont know if thats a factor , good luck peeps
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 23:57 -
DVD to XVID using DVDx 2.20
By Immortal25 in forum DVD RippingReplies: 0Last Post: 2nd May 2010, 07:20 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 02:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 09:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 15:17
