I have a bunch of 1080p .mov (Photo-JPEG codec) clips that I want to downconvert to SD NTSC. I have fiddled around with the trial versions of Sorenson Squeeze and DV Kitchen but am not satisfied with the output. Maybe I'm doing something wrong, but it looks too soft. Can anyone recommend software that will do a good job downconverting and give me some ideas about settings for best output? Either Windows or Mac recommendations will be fine.
It's amazing to me that no one has tried to answer this question. Is it really that difficult? (Perhaps it was too open-ended or not specific enough.)
Neither Sorenson nor DV Kitchen did exactly what I was looking for. QuickTime Pro was the answer! I used the same Photo-JPEG codec to do the conversion. Of course, any compression from HD to SD is going to reduce quality. I was simply asking for software recommendations in order to find that sweet spot between quality and file size. -
You didn't specify what codec you wanted it in and what purpose it was for. But most likely people just happened to miss your post (easy to do if you only look at the New Posts page).
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Recommendations for AVISYnth NTSC video (60i) to PAL video (50p)
By csdesigns in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:33 -
Need software that identifies PAL/NTSC
By djkilla in forum Software PlayingReplies: 5Last Post: 20th Jul 2008, 19:03 -
Recommendations for database software for my home video clips
By lariol in forum Newbie / General discussionsReplies: 0Last Post: 9th Jun 2008, 13:49 -
PAL->NTSC ripper software?
By coody in forum DVD RippingReplies: 4Last Post: 8th Oct 2007, 23:50
