I posted this text:
But instead of this:HTML Code:Read this: [URL="http://www.aquilinestudios.org/avsfilters/index.html"]Scintilla's Guide to AVISynth Postprocessing Filters[/URL]
Read this: Scintilla's Guide to AVISynth Postprocessing Filters
the result was was this:
Where the word "Avisynth" in the middle of my URL tags is "tool linked", messing up my link.
Also I notice that words in CODE tags are parsed and linked to tools -- this is really annoying and can break code. I found that using the HTML tag does prevent parsing, as above.
I know that I can disable parsing of tool links per post by unchecking the option, but if I forget, the text is scrambled; if I go back to correct a typo, the "parse" option is reselected and cannot be unselected unless you click "Advanced" -- but clicking "Advanced" causes the tool links to be parsed before I can turn it off!!!!!!!
Anyway, I think that text between URL or CODE tags should never be parsed into tool links.
(I had to edit and reedit this about 6 times to do and undo all the parsing....)
Yep. It's annoying. I will see if I can tweak my tools replace regular expression.
I think it should work pretty good now.
Url with dvdrebuilder textCode:\tmpgenc bd rebuilder loadplugin(\"P:\AviSynth 2.5\Old\LoadPluginEx.dll\")
Code works fine with urls is not that simple to fix...Last edited by Baldrick; 30th Aug 2010 at 04:10.
And now a new, almost as annoying problem:
If I post this text:
in CODE tags it adds backslashes to the quote marks:.
And for extra laughs, every time I edit it, it adds a new set of backslashes. So I getCode:loadplugin(\"P:\AviSynth 2.5\Old\LoadPluginEx.dll\") DirectShowSource(\"file.xyz\") Soundout()
after a couple of edits.loadplugin(\\\"P:\AviSynth 2.5\Old\LoadPluginEx.dll\\\")
DirectShowSource(\\\"file.xyz\\\")
Soundout()
Why does the forum software insist on screwing with code?Last edited by AlanHK; 30th Aug 2010 at 01:23.
It's not the forum software that causes this...it's my crappy code.
I disabled the tool linking when editing until I found the bug.
Parsing SVC SSEI
By link3D in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2010, 00:49 -
add Disable automatic tool link to quick reply?
By lordsmurf in forum FeedbackReplies: 0Last Post: 12th Apr 2010, 10:51 -
parsing an avi file
By pi-1966 in forum ProgrammingReplies: 0Last Post: 27th Apr 2009, 06:08 -
Parsing error
By screenhoofd in forum ffmpegX general discussionReplies: 6Last Post: 6th Oct 2007, 08:17 -
Such thing as dual link to single link DVI-D cable?
By Mizkreant in forum DVB / IPTVReplies: 1Last Post: 14th Jul 2007, 06:51
