Here at work we've had the Panasonic AG-HMC150P for a few weeks. I've noticed that, sometimes when panning, the image makes a sudden "jump" left or right. What could be causing this? Is there some sort of image stabilization that's operating incorrectly? I haven't found anything from a glance through the menus and manual. I hope it's nothing defective with our camera, or a flaw with the model.
try turning off the Optical Image Stabilizer (OIS). if that corrects it, i might have the camera checked out by a tech. the OIS should not cause visible "jumps".
Thanks! Sorry, my lack of knowledge with technical terminology sometimes leaves me not knowing what a lot of buttons do! I turned the OIS off. I'll have to do a few tests, but I'll see tomorrow if that solved the problem.
http://www.kiva.org/about -
We have two cards at the moment, both brand-new. They're PNY, 16GB Class 4. I'm not even recording at max settings, 720p, 30fps. I see the effect both while recording and in playback. I didn't know that the cards can slow with use, though. I'll have to keep that in mind.
Anyway, I'll do some tests tomorrow to see if the OIS being turned off fixed the issue. -
It must be a camcorder setting or a defective unit. Call Panasonic support.
Panasonic DMR EZ28 - Tape Feed is Jumpy
By Garyrajsich in forum Capturing and VCRReplies: 3Last Post: 7th Feb 2011, 20:18 -
Question about slight 1 second jerk when camera pans
By jimdagys in forum Authoring (DVD)Replies: 31Last Post: 5th Apr 2009, 09:39 -
slow pans are jerky on DVD after Premiere Pro exports
By spicediver10191 in forum Authoring (DVD)Replies: 15Last Post: 6th Nov 2007, 21:59 -
"Sliced" playback during pans and action scenes.
By GMaq in forum Software PlayingReplies: 9Last Post: 1st Nov 2007, 10:07 -
How to remove stutter in pans ???
By stars in forum Video ConversionReplies: 1Last Post: 11th May 2007, 10:03
