Hi!
I have a friend who uses movie scenes for some classes (conferences) he gives. However, it's not very comfortable to put a DVD on the computer and then selecting the scene and playing it. He has most movies on DVDs and some others in AVIs.
I wanted to know if there was an easy way (because he is not keen on computers, just an average user) to select the scenes and cutting them.
So far, I've tried DVD Knife, which is very easy. But I cant load subtitles on it!!Is there any program that can cut the movie LOADING subtitles?
The other option I thougt was converting his DVDs to Avis (Xvid)..(What easy, and free if possible, program do you recommend?) and then pasting the subtitles on them (hardcoding is the name? I would do it with AVI Recomp) and then, again, cutting the avi (Again, What easy, and free if possible, program do you recommend for this?).
Thats all. The main objective is to make it the easier and shortest way. Thank you for your patience, and thanks in advance.
cutting out scenes from video files
By stallion2008 in forum EditingReplies: 3Last Post: 17th Apr 2011, 14:06 -
Audio out of sync after cutting scenes from an MKV file with Avidemux
By kr1ge in forum EditingReplies: 1Last Post: 23rd Oct 2010, 14:08 -
Ability to rip scenes only and cutting out everything unrelated
By alex_ac in forum DVD RippingReplies: 12Last Post: 12th Oct 2010, 14:56 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 08:18 -
Cutting scenes from dvd using Nero
By aelfheah in forum Authoring (DVD)Replies: 0Last Post: 16th Jul 2007, 12:57
