hi ppl
i ran into a proplem , i'm trying to burn rat race to vcd . i use vdub to do the audio no proplem there , when i used tmpgenc it said that the video was unsuported ? does anyone know what i can do to get this movie to vcd ?
i'm useing vdub for audio
hopefully tmpgenc for the video
and vcdeasy or nero to burn
Well if you can view the movie in Vdub, I guess you have the codec installed, TMPgenc gives that message if there is a codec missing, but the AVI could be messed up a little.
Try loading into Vdub, select streaming for audio and video and save out another copy (few minuets), then try that.
Click your right hand mouse button on the AVI and select properties, this shows you the codec that was used to make the move. Go to your control panel, multi media >Devices >video codec's and see if the codec is there.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 15:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
