When ripping television episode DVDs for my library I usually use Fair Use Wizard with no problems.
Fair Use will break it down for me and show the separate episodes so I can select what to rip set options etc...
Well the DVD I am working with at the moment has 6 episodes on it but only one chain is showing up in Fair use at a duration of 2:19:50 which is the duration for all 6 episodes.
My question is, how can I rip the 6 episodes (single chain) from the DVD to 6 separate XviD .AVI files. Is Fair use wizard the wrong program for this situation? What is recommended for what I am trying to do?
Thanks for any advice...
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind...
The only answer is to do a two-step process. Rip with something else where you can pick one episode at a time.....then re-encode to xvid.
And if they're all in the same PGC, that means DVD Decrypter in IFO Mode set to decrypt the correct number of chapters per episode.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Ripping 50 DVD chapters to individual files
By indijay in forum DVD RippingReplies: 2Last Post: 16th May 2010, 03:05 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
dvd shrink: single large file or multiple small files
By avextraxjp in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 22:43 -
help with ripping the individual episodes from the dvd and converting them
By dvdrburner in forum DVD RippingReplies: 1Last Post: 22nd Aug 2007, 08:14
